Toshiba model 50a62 had no color just black and white
    Top Expert:
  • Televison & ... Master
  • 75,452 Answers
Check its chroma processor section circuit.
Posted on Apr 30, 2013
3 Suggested Answers
asnowman
  • 788 Answers
SOURCE: Toshiba Model No. 50A62 When the set is first
It sound to me like your tuner is going out. I would suggest that you contact a local service center to get the tuner replaced or just put up with it as long as you can.
I hope this helps.
Thanks
asnowman
Posted on Sep 21, 2009
  • 14 Answers
SOURCE: how to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Posted on Jan 29, 2010
Toshiba 50a62 no color, just black and white. Could I just replace the rgb bulbs to fix the problem?
No color is not the problem with its bulb. It must be a problem to its chroma processor section circuit. If you have knowledge in electronics, you can do the repair by yourself. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 30, 2013 | Televison & Video
Where is the remote sensor for the Toshiba 50A62?
Hello
Remote sensor is an internal component, and can be locakted just beneath the remote sensor window at the front panel of all TVs. It is usually a three terminal black colure component, diretly soldered to a circuit board. In some sets, it will be on a seperate circuit board, and in some otheres it will be soldered to the front panel control switches board. OK.
Mar 06, 2011 | Toshiba 50A62 50" Rear Projection...
Scan Color document by Toshiba E-Studio 45
E-studio 45 or E4500 is a black and white copier. Hence, it can only scan original document to black and white only. There are some copiers which have the color scan capability but not this one.
Feb 03, 2010 | Toshiba e-Studio 45 Black and White Copier
How to clean a toshiba tv screen model # 50a62
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
Toshiba Model No. 50A62 When the set is first turned on, the screen is black with white snow and no sound. After 5 minutes, we get a normal picture. I get the same results, everytime it is turned off and...
I hope this helps.
Thanks
asnowman
Sep 21, 2009 | Toshiba 50H82 50" Rear Projection...
Remotes do not work
You can quickly test the remote in question with a digital camera... please vist my Tips & Tricks so see how.
Jan 23, 2009 | Toshiba 50A62 50" Rear Projection...
Blue doesn't work
replaced the blue crt drive pcb or the large transistor on the crt driver pcb.
Jan 08, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba 50A62 blurred screen
does it look like these?
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 03, 2007 | Toshiba 50A62 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
