Whirlpool cabrio No power unplugged it plugged back in heard beep, but digital screen not showing anything and nothing works.
  • 25 Answers
Got a error code, was there a power surge before this happened? If not then you can assume that your LED screen died. Unless your good at electrical issues, call customer support and see if they have a easy troubleshooting guide for it. If not, then you will need a new screen for it to make it work.
You can check the power outlet, try plugging your dryer/washer into the other plugin, see if it works or doesn't. Might be that. Or use a DMM "digital multimeter" (if you know how) and check the outlet.
good luck
Posted on Apr 30, 2013
  • kcooper74 May 01, 2013
    Thanks but some reason I tried bout 3 or 4 times. Then I turned the dial and it started back.
Whirlpool cabrio is giving a code which is f1,
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows F1 top load cabrio whirlpool washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code Whirlpool cabrio
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio F1 fault code
Sep 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer WTW6600S turns on but does not do nothing
Try unplugging it for a few minutes then plug it back in. If it does not reset then the controller requires replacement. Hope this helps... Bill
May 31, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Apr 08, 2009 | Whirlpool WTW6400SW Cabrio Washer
My whirlpool cabrio washing machine keeps flashing F1?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Mar 28, 2009 | Whirlpool WTW6400SW Cabrio Washer
Du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
try to remove as much water as possible ..wet vac will help pull unit out remove back cover lean washer forward on left bottom is drain pump remove 3 screws holding pump and clamps holding hoses on pump..on motor side of pump are 4 screws remove them noting location and orientation of pump body clean out ..ck impeller ..round white part with fins ..if it is not broke try turning it by hand should turn but with some resistance if free wheels replace pump if you found stuff in pump reinstall and ck
Aug 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
