Right keys don't work
My HP 32sII calculator was functioning perfectly fine. It fell by accident and now none of the right side keys function. What do I do to fix it?
What the answer to 7,530miilmeters= - centimeters
Posted on Apr 30, 2013
SOURCE: Calculator is stuck in Binary mode
Try this. Press MODE and then number 1 ... This worked to me. And then with DRG you can change to DEG, RAD or GRAD ... I hope I helped :)
Posted on Dec 13, 2007
SOURCE: finding function "e" on TI-36X Solar calculator
buy another one
Posted on Oct 16, 2008
SOURCE: TI-84 Plus: Calculator Unresponsive
Try pressing the "On" button a couple times. That should work
Posted on Jan 30, 2009
SOURCE: Non functional keys
HP 48SX and HP 48GX calculators have a membrane which connects between the internal circuit boards. This is a common failure point. The "ON" button is often the first button to go out. The calculator can be opened up can cleaned, but it is a little involved. Forutnately someone has posted pictures and information on what to do.
http://www.hpcalc.org/hp48/docs/opening/hprepair.zip
There is a text file with information. The file is big because of the pictures. Summary: Open the case, bend metal clips holding the circuit boards together. Clean up any dust and the contacts. Reassemble.
Posted on Mar 02, 2009
  • 7993 Answers
SOURCE: HP 15C calculator display showed
When you get the error press any key to suppress the error message. Put the calculator into PROGRAM mode and you will see the line where the error occurred.
Here is what the manual says for ERROR 4 (free translation)
The line number called is not used or does not exist (larger than 448); attempt to load a program line (instruction) where there is not enough space; line label inexistant.
My hunch is that you are attempting to divide by 0: The quantity of which you are taking the reciprocal (inverse function has another meaning) may have a 0 value.
Do not forget to check the input values.
Hope that will help you debug your program
Posted on Oct 14, 2009
I HAVE REPALCED THE BATTERIES AND IT WILL NOT POWER ON.
The HP 32SII calculator has a very common problem with the keyboard connections. There might be nothing else wrong with the calculator except the contacts.
Try pinching the calculator just below the middle of the screen above the [LN] and [Y^x] keys while pushing the [C] button to power it on.
If this worked, at least you know where the problem is. Fixing that problem temporarily, some users wrap a rubber band around the calculator at that point and put something under it to keep pressure on that spot.
The longer-term fix is harder and involves taking the calculator apart to replace a foam pad to keep pressure on the plastic keyboard contact strip against the printed circuit board contacts.
Somebody (not me) put together an Instructables page for the HP 17B calculator, which is built exactly the same as the 32SII.
HP 17b series calculator repair
Nov 30, 2015 | HP 32Sii Scientific Calculator
Hp 32sII enter degrees minutes seconds
According to the "HP 32SII RPN Scientific Calculator Owner's Manual" (at the link below), you just need to treat degrees, minutes, and seconds conversions as hours, minutes, and seconds. Use the left-shift and right-shift keys together with the 5 key to convert to decimal-fraction form (D.d format) and to minutes-seconds form (DD.MMSSss), respectively.
http://www.hp.com/ctg/Manual/bpia5305.pdf
See pages 4-9 and 4-10.
hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-0.jpg hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-1.jpg
Apr 09, 2014 | HP 32sII Calculator
Compute the nth root
The nth-root function is the right-shifted function of the square-root key, second column from the left, fifth row from the top.
In RPL mode, to calculate the third root of eight, press 8 ENTER 3 right-shift [nth-root] and get 2.
In algebraic mode, press right-shift [nth-root] 3 right-shift [,] 8 ENTER and get 2. (The comma is the right-shifted function of the SPC key on the bottom row.)
Oct 01, 2012 | HP 50g Graphic Calculator
How do i get inv on my TI-84 Plus caculator
To get the inverse trigonometric functions press the 2nd key then the trig function key. If you'll look at the key legends above the SIN, COS, and TAN keys you'll see the standard math notations for their inverse function.
Apr 05, 2012 | Texas Instruments TI-84 Plus Calculator
The LEFT KEY on my mouse is doing the functions of the RIGHT KEY (the drop down window) and the RIGHT KEY is doing the
Try going into the Control Panel and navigate to mouse properties. There is an option there to reverse the button functions.
Dec 20, 2011 | HP Computers & Internet
When I try to solve a sine, cosine, or tangent problem, it comes out differently than the real answer. Other keys work fine though... ex: sin(37) Real: .6018 Mine:-.6435 How do I fix this?
When you use trigonometric functions you should always make certain that the angle unit the calculator is configured for is the intended one.
When the unit is set to degree sin(37)=0.6018
When the angle unit is set to radian, sin(37 rad)=-0.6435
Change the angle unit to degree.
  1. Press the MODE button
  2. Scroll to reach the Angle line.
  3. Use right arrow to highlight deg and press ENTER to validate.
Jun 09, 2011 | Texas Instruments TI-83 Plus Calculator
Brother i have just opened a wireless network but my wireless network is not working properly. Can u plz contact me for some help i shall be very thank full to you if u do this favour for me. Thanks...
Troubleshooting issues with wireless connectivity can be tricky. There are a bevy of potential causes for drops in the connection, slow-downs in throughput and sporadic signal loss. As such, it's best to take a shotgun approach, throwing a number of possible fixes at the problem and hoping one sticks.
Check if your laptop's wireless switch or button is turn on - look around the laptop in front, back or sides. Sometimes you might touch to turn off accidently and you don't know. Many laptops have the wireless light indicator, check if the wireless light is on and blinking.
Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the wireless, which is to control the wireless connection of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, touchpad etc. You will need to hold down the Fn + F8 combination keys together, in this example the Toshiba laptop's wireless setting.
  • 3
    Check Network connections; make sure the laptop connection is not 'disabled'. It should has the gray color if it's disabled. Right click on it and enable it.
  • 4
    If none of the above works, you will need to enable the Wireless Zero Configuration in services.msc (type this in from Run command), or you can see it this way: Right click My Computer -> Manage -> Services and Applications -> Services.
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJNokX7
  • 2
  • 3
  • 4
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJ8lq45
    May 07, 2011 | Computers & Internet
    I have a HP 32sII and the screen has gone fully on. All the displays are on at once. I replaced the batteries, that did not help. Any suggestions?
    Hold down "C" key. Press and hold both top left and top right key along with "C" key. Release all three. Reset.
    Dec 21, 2010 | HP 32sII Calculator
    On/off button very hard to make function. Once
    To reduce the problem size by half, let it power down automatically, after a short peiod of idleness.
    Hope it helps.
    Feb 28, 2009 | HP 32sII Calculator
    Non functional keys
    Sep 21, 2007 | HP 48gx Calculator
    32 people viewed this question
    k24674
