Question about Philips 26MF231D 26 in. LCD Television
Magnavox 32mf23 The TV does not turn on the Led light does not light up. I tested if there was a connection at the led light and the plug there is a connection, the fuse above the plug in is OK. Can you help me?
    Top Expert:
  • Philips Master
  • 75,404 Answers
Check its main power supply board for all voltage outputs. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
Testimonial: "Thanks,Kumar I will check that,is the main power supply board the board with the outlet on it? If not how would I know that it is the main board?"
  • 52 Answers
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Posted on Aug 19, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
Posted on Jan 09, 2009
SOURCE: Magnavox 42MF130A/37, no picture
IF your not getting sound and its shutting down it could be a the main board, or the power supply (huge board in there.) I just got done parting one of these tvs that was in a vacation rental. the tv met with an unfortunate accident so the screen was cracked and so on. Anyhow if your intrested i have the main board and the power supply board for that exact model. I was listing them on ebay and saw this post. Listing here. I am going to probaly get about 25 buck a board (very cheap) plus shipping. IF your intrested let me know and I list that power supply board as well. I can't guarentee it will fix it but its worth the shot for 50 plus shipping. form my experience with mostly LCD tvs if your not getting sound odds are its the main board. I also listed what was refered to as the signal scaler (logic board)
Posted on Sep 19, 2009
  • 63 Answers
SOURCE: 50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Posted on Aug 03, 2010
How do i fix a samsung lcd led tv burned out led backlights?
hi if its led backlit then there are strips of leds mounted within the screen assembly....each strip plugs in and you can test each strip by connecting 15-20v across each strip to see which does not light up...then replace that strip
Dec 30, 2015 | Samsung Televison & Video
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
Looking for the codes for a 32'' magnavox led tv
they will be listed in the instruction or owner manual for the set or the remote being used.
Sep 02, 2012 | Magnavox 32 in. Class LED 720p 60Hz HDTV...
Was watching tv lastnight and the TV just shut off. I have unplugged it for the 30 mins that it recommends for it to rest. That didnt work. Any suggestions? Thanks
Now,the tv turn on,the front of LCD screen panel the power LED light is blinking or no power LED light indication nothing at all?Yes.The tv power supply board have problems,it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Magnavox 32MF338B 32 in. LCD HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Magnavox codes
Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
Jul 18, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox TV will no longer turn on
Does it beep .. or anything? Does the front LED come on?
May 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 26MF231D 26 in. LCD Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
