Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Posted on Apr 30, 2013
I have this same problem with my Artisan mixer. I've adjusted the clearance screw to no avail... and no, I don't have the wrong beater... any other suggestions... ?
Posted on Jun 17, 2013
defrankond
  • 65 Answers
SOURCE: Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Posted on May 05, 2008
advacak
  • 125 Answers
SOURCE: New kitchen aid Beater does'nt fit
you got the wrong beater
Posted on Dec 31, 2008
hslincoln
  • 235 Answers
SOURCE: mixer component vibrates
Hi, LAHR, by the symptoms you describe it appears that it’s time to adjust your mixer’s "Beater to Bowl Clearance" adjustment screw, which should be a pretty easy to do by yourself.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of it from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 10, 2009
Testimonial: "Thank-you! That solved it."
  • 130 Answers
SOURCE: cant adjust flat beater so it wont hit the
all tilt head mixers pivot on a pin which goes thru the head and the base. This pin is held in in place with a screw which you can access from underneath the base. Try tightening the screw and see if that tightens up the the loose head.
If the looseness is in the gear head then the five screws which hold the top and bottom halves of the gearcase together. Remove the chrome ring by gently prying it off, then drive the pin out which goes thru the planetary housing and the shaft and drop the planetary housing to access the 5 (item 19) screws.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
Posted on Apr 06, 2010
  • 130 Answers
SOURCE: mixer head is loose
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Posted on Apr 11, 2010
Kitchen aid model kg25. vibrates and beater hits bottom of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Dec 30, 2014 | Food Mixers
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Planetary assembly low and beater not locking
Edward, it sounds like your planetary is starting to separate.Where the center shaft connects to the planetary commonly separates, the pieces are machine pressed together, and can separate, usually your beater, and planetary plate will just fall off into the mixer, while the center shaft stays up inside the mixer with the gears on it.
What you will need to do is buy a new planetary assembly, you do also have the option to have it pressed back together by a machinist, but it is usually cheaper just to buy a new planetary. According to your model number you have a Onyx Black mixer, here is a link to the replacement planetary on our website: http://www.mendingshed.com/9708176.html
That should solve your problem, also here is a link to the service manual in case you need any help taking the mixer apart: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
And of course, if you need any help you can call us and speak with a KitchenAid technician over the phone
Thank you,
Colleen
Customer Service
MendingShed.com
Feb 25, 2014 | KitchenAid Food Mixers
Professional 600 575 watts beater shaft is loose
If the beater shaft that you attach the beater to is loose in it's housing, then you will need a new planetary for your mixer, it is a relatively easy fix to make, but you will have to order the part before you can effect a fix.
The 600 model has the center shaft attached to the planetary by means of a heat pressure press in. Which means that when the colored rotating part starts to come loose that you have to replace the whole planetary piecec994bebd-6a21-41c8-821e-a90ec9e3ea14.jpg
the piece that the beater attaches to is called the agitator shaft and it will need to be removed and put on to the new planetary when you install the new one. If the agitator is actually the piece that is loose then you need a gear at the top, a pin underneath of the gear, or a snap ring that holds the shaft together in the planetary housing. Go to the kitchenaid address listed here>> http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
when the page opens look on the left side of page and fill in the proper model number (it is on the bottom of your mixer on a white tag), the page will give several choices go to the parts list section and click on that choice for your model number, (you will need the proper part number to order the correct color for your mixer, by following the parts list diagram you will see that there is a very understandable process that you can follow to open up the mixer and replace the planetary, hope that this helps, let us know if you need assistance or if this answered your question
Apr 17, 2013 | Food Mixers
BBeater scraping back bottom of bowl
Is the planetary still off before the taper pin is in place?
It's a shot in the dark but if everything lines up, I can think of two possibilities:
1. The taper pin in backwards, and
2. The shaft hole in the planetary is out of round.
Mar 20, 2017 | Hobart N50 Stand Mixer
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Cant adjust flat beater so it wont hit the bowl,when trying to the head of the mixer is too loose
Apr 05, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid model KB26G1XGN. The planetary gear appears to be falling out. The mixer blades were hitting the bowl before I had the bowl in the locked position. I got the top of the gear box off but can't...
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
See second comment...
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 12, 2009 | Food Mixers
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
200 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
