Question about Dell Inspiron 560 PC Desktop
Dell inspiron 560 problems
When i press the power button on my dell inspiron 560 desktop,everything seems to come on,all the fans started to spin,the cd drive opened and closed,but nothing showed up on my monitor,its just a blank screen,the monitor goes into sleep mode.the problem isn't the monitor because i connected it to my laptop and it was working fine.i took out the ram and heard the beeping sounds so it cant be the mobo right? i put the ram in a different slot,that seem to work,but whenever i shut the computer down then turned it back on its giving me the same problems i had before.i bought a new power supply because i thought that would fix the problem but it didnt.could this be a ram issue ?..also my hdd light wont light up...
    Problem Solver:
  • 7 Answers
Chek your video card it my be going out
Posted on Apr 30, 2013
Testimonial: "how would i do that? "
  • 55 Answers
SOURCE: Dell Dimension 4600 Won't Boot Up, Steady Amber Light is on tower
It could very well be the Mobo or the power supply. You may want to try to take the CMOS battery out for a few mins as well, I have had problems with that. But I would try PS first, get one from Circuit city or another electronics store and if it doesnt fix it take it back. I dont know if you know a lot about computers but you could buy a new Mobo just make sure the Ram and Processor match up
Posted on Nov 30, 2008
edisonfrelan
  • 113 Answers
SOURCE: Monitor displays breifly then goes to blank screen
try booting up your CPU again, while on its process of booting press F8, then select (something MODE), okay, then when you are at windows environment go to control panel, select display, set your display settings its default or 900 by 600 pixels settings, then if its run okay then change to your desired settings.
Posted on Dec 17, 2008
lock123
  • 6831 Answers
SOURCE: Computer Wont respond after the RAM was switched. 6 beeps.
Hello
The beep code you are getting is faulty ram. There really is not anything you can do to fix this yourself. Sorry
Best regards
Andrea
Posted on Nov 05, 2009
computerdeb
  • 323 Answers
SOURCE: Dell Dimension 2300 - Boot Up Issue - Replace Motherboard?
I have issues after shipping with wires. Have had to pull and reset wires with the computer unplugged and 80 % of the time that has fixed the problem.
Posted on Jan 19, 2010
Testimonial: "The suggestion was helpful - together with another suggestion, it helped advance the ball. Moving on to another issue now. Thanks."
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
Dell insperon 560 orange light and beeps no display
look to see if fan over cpu chip is running. if the cpu socket fan is not spinning sometimes the pc will not boot. the cpu has to be kept cool so its a safety default. lose connections have been know or broken.
just fixed such a problem by resetting the wires on the motherboard.
Nov 21, 2013 | Dell Inspiron 560 PC Desktop
My Dell Inspiron 560 will not eject a disk.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
If you physically unplug your cd/dvd then plug them back in restart your computer the found new hardware wizard should activate
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Jun 03, 2013 | Dell Inspiron 560 PC Desktop
Dell inspiron 560 power supply problem
This could be either power supply or motherboard problem. If the fans on the motherboard and power supply are spinning then it's probably the motherboard which you can check by removing the memory and unplugging the data lead off your hard drive. It should start beeping.
If not, then it's probably the power supply. They are easy enough to change - half a dozen plugs and four screws. I always replace standard power supplies with a 400 watt one. It will tell you the wattage on the label, I would add 100 to that figure and get that size or bigger - depending what's available.
It will not hurt to replace a 250 watt unit with a 500 watt unit so don't worry about that. It gives you room for expansion.
Jan 15, 2013 | Dell Inspiron 560 PC Desktop
My dell inspiron 560 wont recognize any disc it acts like nothings in it how do i fix it?
Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 20, 2012 | Dell Inspiron 560 (Intel Pentium Dual Core...
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
How to eject cd from dell inspiron
Press the button the cd drive door or click Start/My Computer then Right Click on the CD Drive and select EJECT.
If it is stuck you will need to take a Paper Clip (Gem Clip) and straighten it out. Then look for the tiny hole on the CD Drive door and push the Paper Clip (Gem Clip) into the hole and Press the the button on the drive door. As you Press the button on the drive door, push the paper clip in and the door will pop open.
Don't worry about breaking something, that is why the tiny hole is there.
May 04, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
I dont understand how to or where to put a game disk in to the dell inspiron560?
If you have a CD or DVD drive which is common for dektops computers just push the eject button of the CD / DVD drive once it opens install the the game and open the program after installing.Thanks
Jan 24, 2011 | Dell Inspiron 560 (Intel Pentium Dual Core...
8200 inspiron wont start up
Hi
Assuming the fuse in the plug hasnt blown...do the fan(s) in the power supply go round? If not then the power supply needs replacing.
Sep 25, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 560 PC Desktop Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
