Question about Vizio E320i-A0 32 Class LED Smart TV
Composite Input Not Receiving Signal
I got this tv the the day and I was watching Netflix on it and all was fine until today when I went to hook up my PS3 to the composite input and it shows nothing but the words "No Signal" on the screen. I know its the TV because I tried other things in the com. input and nothing still. Please help me!
  • JT Features
    JT Features Apr 30, 2013
    I found out that the device was set to use the HDMI. So what had to happen is I needed an HDMI cable to see the system and then I could go into the system and set it to use the other.
    Top Expert:
  • Vizio Master
  • 74,136 Answers
Check the cable connected in between. Replace the cable and check.
Posted on Apr 30, 2013
SOURCE: Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
BoiseLCD
  • 63 Answers
SOURCE: 42 in. vizio. just went blank. no sound or pic.
unplug it from the wall and hold down the power button for a few seconds to discharge any residual energy left inside the TV's electronics. Then plug it back in and see if there is any picture, even if only for a moment.
Some sets will have a reset sequence that restores all the factory defaults. This will sometimes bring your TV back around if it happens to get stuck on stupid. You'll have to search Google for your model's reset button sequence. Often it will be something like: With the power off, hold down the INPUT and VOL+ buttons at the same time. Click the power button and continue holding down the INPUT and VOL+ for a few seconds.
Your's may be different, or not at all.
I've seen this fix a TV before. But I've also seen this symptom on a TV that had a bad logic main board. Another thing to try would be a firmware update. See if your TV has a USB port available to do this. It will often be labeled as "SERVICE". Again, you'll need to search the web for more instructions, and for the firmware file itself. Often these can be obtained from the manufacturer's web site.
Posted on Nov 26, 2009
  • 668 Answers
SOURCE: HDMI only works after warming up??
The HDMI inputs do a lot of hand shaking and while hand shaking they sometimes miss the grip. It is all about data and communication not being seen or understood. Sometimes it is a Software issue and the TV and or Dish Box needs the HDMI Software upgraded if available for the respected models. If the Component cables work well and they should, I would just use them. The picture quality is just as good and it works every time.
Hope this helps,
Sky Assoc
Posted on Jan 05, 2010
  • 3 Answers
SOURCE: Vizio GV42LHDTV - No video inputs
my 42 also went black, and the "vizio" logo in front indicates as if it is turned on, it clicks on and off, but just has no output on the screen, meaning not a black screen, just a dead, no image, even when the system has clicked on
I tried turning off, on, unplugging, letting it sit (kind of like a reboot wishful thinking), removed all connections in back, (nothing still, not even the blue screen) just nothing.
What a shame, I had the unit less than 6 months, and now this? I have work to do, and I can't get it done.
Posted on Mar 23, 2008
jomabug76
  • 1148 Answers
SOURCE: External input sources won't receive signal
UNPLUG THE HDMI AND TRY,,
Posted on May 15, 2009
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
Sound okay on tv but no sound on bluray player
Make sure the audio inputs are on the same input as the video cable.
Dec 29, 2014 | Audio Players & Recorders
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I hook up the wires for the dvd player I have a yellow white and red wire from the dvd player
The yellow wire is the one which is the video composite signal and it must go the Video input inthe TV. Choose the Video 1 input. Now the red and the white RCA cordss must go the the L&R Audio input 1 in the TV. Now select the AV1 in your TV and it is ready for use. Choose a good DVD and play. Wow! you are ready to watch your favourite program. Hope this helps. Good day
Jul 02, 2010 | Televison & Video
No signal
You have changed the input to a selection that does not have a signal. Look at where the cable goes into the TV, this should show the name of that input, then change input back to that exact one via your remote.
Apr 19, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Polaroid tv. My cable company came out today and updated me w/ digital tv and dvr. Things were fine when the tech was here and afterwards I watched a dvd and when I switched the input back to the...
Check the back of your TV. Your cable is probably hooked into a Composite or HDMI input, I doubt they would install it directly to the TV's tuner, these days thats reserved for local antenna's.
Jan 08, 2009 | Insignia IS-LCDTV32 32 in. Television
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Vizio E320i-A0 32 Class LED Smart TV Logo
97 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
