Question about KitchenAid Food Mixers
The mixing section has a gap in between
It has a gap in between where it should be
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Posted on Apr 30, 2013
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
The beater will not come off and it's leaking oil
These are two separate problems.
The beater is probably being held on by dried/solidified flour. Try keeping the section where the beater joins the mixer head wet with water to loosen up the dried "glue." (Give it some time.)
The oil leak is caused by the grease separating. You can try running the mixer on high for a few minutes to re-mix the grease. If this does not correct things, you will need to clean out the old grease from the gearcase and replace it with new. See the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 01, 2014 | KitchenAid 32685 Mixer
The rotating head on the mixer keeps falling off. how do you get it to stay on? it comes off when were mixing.
The Planetary plate comes attached to the shaft from the factory. It is not supposed to get
loose and come apart but it often does due to the mixer's vibrations and the user's constant
attaching and removals of the flat beater, wire whip or dough hook onto the beater shaft.
Try to remove the Planetary plate first : Gently rock it from side to side while pulling on it
to separate from the shaft. Notice the groves on both the shaft and inside the planetary
housing. That is how they are attached to one another at the factory (just friction, no screws
or pins). Now for a permanent solution:
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture on both the shaft (grooved section) and inside the
planetary housing. Now re-attach the planetary plate to the shaft. Use a long strip of duct tape
to hold the plate in place (to prevent it from falling back out). Allow the epoxy to dry overnight
or at least for 8 hours.
The Planetary assembly is now permanently attached to the shaft of the mixer.
Jun 10, 2011 | KitchenAid ProLine 600 Stand Mixer
Dough blade is scraping the stainless bowl. The mixing head seems to be sitting lower. In order to lock the tilt I have to lift the head a little.
If you're still having this problem, here's what I did a few minutes ago that fixed it. Lift the head, then turn the screw that connects the head to the base to the left. You're basically unscrewing it. That screw regulates how high or low the beater is. Unscrew it a little at a time, and lower the head and try to lock after each turn. The head will gradually get in a more locked position. Keep turning the screw till the head finally locks in all the way. Read the "beater to bowl clearance" section in the manual.
Nov 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
It makes a grinding sound when it starts up but then runs o.k. It also gets hot after mixing bread dough.
How old is the unit?. Sounds like the armature is poling, ie rubbing against the windings. This normally happens when the bearings are worn - hence the question about age.
If it is not in the motor section, it could be in the gearing that drives the spools.
Oct 13, 2009 | KitchenAid Food Mixers
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My varimixer R30 hook doesn´t seem to reach out far enuff to mix satisfactorily. Can the hook change shape just like that ? Or is the hook for some other kettle ?
This is a dough hook and would typically only be used to knead dough. Therefore, the extra clearance makes sense for kneading dough. For other mixer jobs, use other attachments.
Mar 06, 2009 | Food Mixers
Food Mixers Logo
172 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
