Question about Dryers
My maytag dryer is making a clicking noise and the drum won't spin. I just changed the belt and still not working
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 32 Answers
That's an interesting one. Does the motor run but does not turn drum? If the motor is running but the drum is not turning then there is a possibility that the belt is not attached to the idler pulley correctly. Go HERE to see video on belt install. I have also ran into the screws that hold the tumblers in the tub loose and making noise. Check to make sure there are no screws sticking out of the tub. Contact me at http://www.apcoplus.com/contact.php if you need more assistance or just comment back on FIXYA..
Posted on May 01, 2013
  • scott dearman May 02, 2013
    Thank you for the suggestion. I did check the drum and nothing seems to stopping the belt. The one thing that does not seem right is the piece at the end of the motor that drived the belt is loose. It just spins freely. To me that is wrong. Is that a part I can replace or is that a whole new motor.
    Thank you
    Thank you
5 Suggested Answers
  • 5 Answers
SOURCE: Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Posted on Dec 20, 2008
marka19
  • 1430 Answers
SOURCE: how do i change the dryer drum belt on a maytag
Try this free video www.appliancehelponline.com/servicemanual.html
Posted on Feb 26, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune Gas Dryer will
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 23, 2010
heatman101
  • 43501 Answers
SOURCE: heat works on dryer but won't spin... the drum
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 30, 2011
Maytag gas dryer making keening noise
Bonnie, Belt may be getting bad, change belt and check for worn bearings etc while apart.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 02, 2016 | Maytag Dryers
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Dec 20, 2008 | Maytag Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
