Question about Air Tools & Compressors
Cl6506016 Won't pump air. No pressor
  • 7,482 Answers
Hi Larry
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Posted on May 01, 2013
Compressor on my Coleman cl6506016 is sluggish about starting up What could be problem
I suspect a failing start/run capacitor. have it tested and replace if necessary.
Aug 18, 2013 | Coleman Air Tools & Compressors
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Lifter noice &and it oil lose oil pressor after 30 miles
Sounds like your oil pump is defective. If you haven't taken it to a mechanic, I'll suggest that you do so immediately to prevent further damage to your engine. Good luck and let me know how things play out.
Apr 17, 2012 | Dodge Durango Cars & Trucks
6.6 diesel shut down after starting, still cranking strong but won't start.
I would double check to make sure no air was in line. If it still won't crank, has to be pump.
Feb 21, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
Gdi engine issues
I got the same trouble, launch shows Air Flow Sensor, Fuel Pressur switch. Ireplace both few hours OK but again same trouble.
GDI got a common truble its high pressor fuel pump.
check fuel pressor if its low thats the prob
bye
Mar 23, 2010 | Mitsubishi Outlander Cars & Trucks
Leaks after it builds up pressor
hello, have you checked your pressor relief valve to make sure it has'nt gone bad it's located on the bottom of your tank.
Mar 27, 2009 | Air Tools & Compressors
Discharg pressor
discharge in technical term is the output of the compressor. the discharge pressure. where as the pressor you are referring to could be the compressor. the motor of the unit.
i hope i was able to help you,
tnx 4 using fixya,
drcool
Oct 02, 2008 | Quasar HQ2101SH Air Conditioner
Air Tools & Compressors Logo
292 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
