Question about HP Designjet T1100ps Printer
Print head We have 2 HP DesignJet T1100, which all need to replace Black and Yellow printhead, and we bought NEw geniune HP printhead and after replacement, the printer tells that the printhaed faulty, ok, that's fine, we put the second new one in, it still says it's faulty. How can I solve this issue? Many thanks
Update your firmware.
Posted on May 22, 2013
ctf1800
  • 4402 Answers
SOURCE: Printhead
sounds like a cable is off or broken.
Posted on Apr 24, 2008
mayur47
  • 39 Answers
SOURCE: HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Posted on Aug 17, 2009
mishrajk21
  • 202 Answers
SOURCE: HP Designjet 500, I have replaced the black print
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Posted on Jul 06, 2010
SOURCE: I have an HP Photosmart D7560 printer. It worked
You may need to clean them manually. Take out each cartridge, clean its electronic panel with tissue soaked in a bit of methylated spirit. Also clean the area of contact in the carriage for each cartridge.
If patiently and carefully done all the colours will begin to print; so long as they are still flowing at the nozzle (not dried at the nozzle). To check if they are not dried at the nozzles, apply folded tissue to each cartridge nozzle and press gently, upon removing it, it should come out well/stained with the respective colour. If not you should place in a saucer or plate with a bit of water. Leave for about ten minutes. Then apply the folded tissue again. Ink should blot it well now. If not it means your ink is dried out and you may need to replace that cartridge.
Good luck and God bless!
Posted on Nov 13, 2010
  • 22 Answers
SOURCE: My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Posted on Feb 27, 2013
Printheads in Designjet 510
Alexander, did you do the allignment after changing print heads?
Feb 01, 2014 | HP "designjet 510 24 in. inkjet printer"
I have hp designjet 450c..the problem in printing.while printing it prints copy of the image also and not clear.i dnt know whts the problem..please help me..
That usually is caused by clogged or damaged printheads. There are 4 printheads, Black, Cyan, Magenta and Yellow. When you replace the printheads you need to calibrate the machine so the colors line up with one another.
Jan 23, 2014 | HP DesignJet 450c InkJet Printer
Hp designjet z2100 keep asking to replace the feed heads of magenta and yellow even after replacement and print block of magenta + yellow.
Try to clean printhead contact , i mean in the arriage not in the printhead, if still asking for printheads , try to enter in digonstic mode " service mode " ,,,, hope help you mohamed hejazi
Apr 01, 2013 | HP DesignJet Z2100 InkJet Photo Printer
I bought and replaced the black and yellow printhead today. It printed some colored pages. Then when I began to print this evening a colored page. It stopped in the middle of printing and the printer...
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
Sep 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
Print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Sep 23, 2008 | HP DesignJet 1050c plus InkJet Printer
HP Designjet T1100ps Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
