Question about Garden
Weed eater lawn tractor won't start bought new battery but still w2on't start
  • 7,482 Answers
Hi bigfred9
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on May 01, 2013
5 Suggested Answers
  • 279 Answers
SOURCE: weed eater won't start already Tried new plug
Did you check to see if the plug fires? If it shows a spark, check the air filter. Did you prime the carb? Does the fuel mixture mive smoothly through the plunger? If all that is okay, go through the carb. You might take a SMALL amount of fuel mix and put it into the spark plug hole, try to fire it. If it fires, probably your problem is the carb or fuel delivery to the carb....Good luck...Lee
Posted on Aug 28, 2009
  • 961 Answers
SOURCE: need a manual. I have
Check power at the solenoid and, if you have power there, try to jump it. You should have a safety switch under your seat that could be your culprit. If you have power at the solenoid and it's not the safety switch. Try to pull the starter and jump it manually, by hooking ground to it(housing) and a hot to the post. If it turns over, it's the safety switch or the solenoid, could be the ignition switch but you can jump taht easy enough also. You should be able to jump the safety switch.
Posted on Jun 27, 2011
kvillelocksh
  • 5 Answers
SOURCE: My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Posted on Mar 25, 2012
  • 688 Answers
SOURCE: electric weed eater smokes and won't start
The motor and/or shaft is seized. Loosen it, oil it, try again. You may have fried and ruined the motor windings...that smoke is the varnish insulation on the wiring burning...
Posted on May 06, 2012
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
Weed eater one friction disc problem
HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
Aug 22, 2012 | Garden
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
What ratio of oil and gas do I mix together? How do you start it? I bought the weed eater used.
If you bought it used, you can bet that they didn't run it out of fuel before they stored it, so the gas evapoated out of the carb and all that was left was oil, so mix your fuel 8 to one eight parts gas and one part oil, you'll have to hit the primer botton several times.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
New wife has cc4125. How do you replace trim wire
Hello South Texas from former Mesquite resident!
If this does you any good, get your Model and Serial no. and can go to this web address and download the owners manual:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=30000
Sep 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
