Question about Sewing Machines
How do I fix my Singer 15- 91
My singer 15-91 has lost it\'s power in the sewing drive and won\'t go through thick materials anymore even when I turn the balance wheel by hand.
    New Friend:
    Problem Solver:
  • 7 Answers
Make sure the machine is oiled properly and motor not burned
Posted on Apr 30, 2013
2 Suggested Answers
cherry_davie
SOURCE: singer stylist 534 sometimes when you stop won't start without turning balance wheel
Yes this is normal especialy with heavier fabrics. It allows more control so you build up speed gently. It is also related the limited power of the motor.
Posted on Mar 01, 2013
I've lost a singer 6180 brilliance power cord and need to find a replacement.
call or email these sites and ask them about the part
sewvacdoctor.com
a1sewingmachines.com
Feb 12, 2013 | Singer 6180 Sewing Machine
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
The spindle won,t move on my singer model 237 how do i fix it?
normally when the spindle won't move it's possible that is damaged or a broken part
try some sewing machine oil on it & see if it will free up the spindle
Mar 20, 2012 | Singer Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
Sewing Machines Logo
140 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
