Question about Car Audio & Video
Rca subwoofer sw200p
It keeps frying anything i hook it up to how do i fix it
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Get a bigger amp....a much bigger amp. And dont get **** brands
Posted on May 10, 2013
Hooked everything up in my car right but still no
hook your personal music player to sub amp turn on see if it works if so check settings in head unit or rca wires
Sep 07, 2014 | Car Audio & Video
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
My amp will go into protection mode when i turn my truck on, it flashes green and beats once,then turnd protection mode on... whats wrong with it??
im not sure what is wrong but i do know if you keep it hooked to subs it will fry them because that happened to my friends jackhammer amp and 2 12" mtx jackhammers
Mar 10, 2010 | Fusion FEW12PK Car Subwoofer
Which is the best way to hook up a Subwoofer?
Last two questions first - YES, use an RCA splitter to share sub line level out between two subs and use one at the subwoofer end to share that line with both inputs on the sub.
Either attachment scheme you describe would work.
Not being a big fan of conversion/deconversion for no real purpose, I would avoid stepping the high-level input down to line level for use by the sub's internal amp, run RCA to the sub(s) and keep them physically and electrically independent of anything else unless cable routing is facilitated somehow by daisy-chaining other speakers from the sub(s).
Jan 17, 2010 | KLH PSW8100-8 Subwoofer
I have 2006 ford five hundred limited im trying to install to 12" subwoofers and an amp but i wanna keep the factory radio installed what do i need and can it be done
Hi what you need to find out is if your head unit has sub out or any rca that you can hook up to as they send sound to amp though rca cable hope this helps
Oct 19, 2009 | MA Audio 800XL Car Subwoofer
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
Looking to see if there are rca hook ups on subwoofer
There are not RCA Hookups on any Raw Subwoofer. An amplifier takes an RCA input signal (DC) and turns it into AC to the speaker.
This is a raw driver. It has wire push terminals just like any other driver (speaker).
See here....
Thanks for using FixYa - A FixYa Rating is appreciated!!
Jan 22, 2009 | Diamond Audio TDX-10D4 Car Subwoofer
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Car Audio & Video Logo
    32 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
