Calculator Screen Issues
My calculator screen is having issues. Please help. The numbers will not display properly. How can I fix this?
  • 3 Answers
Take the batteries out maybe.
Posted on Apr 30, 2013
  • 2 more comments
  • ally blooman Apr 30, 2013
    Thanks but I already tried that. I think it has to do with the settings
  • Javamcp
    Javamcp Apr 30, 2013
    Yeah.I was thinking you probably tried that.Have you changed any settings recently?
    Not that I know of but it was in my bag. I am playing around with the settings right now though thanks :)
  • ally blooman May 02, 2013
    Still need help
HP 35s in OCT mode, calculations don't work
There are two separate issues here.
Your calculator is in Algebraic mode. To switch to RPN, press MODE 5 .
Your calculator is also in Octal mode. To switch to Decimal, press right-shift 1 1 .
Mar 24, 2014 | HP 35s Scientific Calculator
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Dec 06, 2013 | Casio FX-300 Plus Scientific Calculator...
How do you move the 'd' sympol off the casio fx-82ms ?
The "D" at the top of the screen indicates that the angular mode is set to degrees. You can change the mode by pressing the MODE key repeatedly until you get to the "Deg Rad Gra" screen and then choosing one of them, but no matter which one you choose you'll get a letter at the top of the screen reminding you of the current mode.
To change the way numbers are displayed, press the MODE key repeatedly until you get to the "Fix Sci Norm" screen and then choosing one of them. You can choose Fix and then press a digit specifying the number of digits after the decimal point, or choose one of the Norm modes and let the calculator show all nonzero digits after the decimal point.
For more details, see the manual: http://www.fixya.com/support/p3846977-casio_fx_82ms_2_line_display_scientific/usermanual-129D386-pdf
Apr 11, 2013 | Casio FX-82MS Scientific Calculator
Screen does not display numerals in daylight
Your calculator has been exposed too UV light there is no fix to this problem. Make sure you LED lens stays out of direct sunlight.
Jul 26, 2012 | Texas Instruments TI-307 Calculator
Screen does not display complete numbers
Half of the display is only working, the problem is in the driver ic that drives the display, it is simply not cost effective to repair the item, further ahead to replace the calculator.
Mar 06, 2012 | Texas Instruments TI-30X-IISTK Scientific...
Horizontal blank line across ti 83 display please help
Press MODE on the calculator.
Select Full on the screen.
You should now have a full screen.
You could also reset the memory.
**THIS WILL DELETE EVERYTHING ON YOUR CALCULATOR**
Press 2nd + (+) which is MEM
Go to Reset which should be number 7
Select All RAM which should be number 1
Press Reset which should be number 2
Mar 03, 2011 | Texas Instruments TI-84 Plus Calculator
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Oct 01, 2009 | Casio FX-115ES Scientific Calculator
"Fix"
The top of the screen displays reminders on the current configuration of the calculator. The FIX will disappear if you change number display to SCIentific or ENGineering, but it will be replaced by SCI or ENG. Why does it bother you, since that part is reserved for the calculator's usage?
Hope it helps.
Jul 25, 2008 | Sharp EL-531VB Calculator
Display issues
It has recently happend to me with my sharp calculator. Experts says that it has no fix and that it would be cheaper to buy a new one.
Nov 30, 2007 | Sharp EL-531VB Calculator
661 people viewed this question
jasbo
jasbo
