Question about GE DCSR483EA Electric Dryer
Ge repair manuals
No light when door is open, unit won't turn on, but the light will come on when the common wire from the door switch is shorted to the chassis. Have replaced the door switch but still nothing.
  • GE Master
  • 8,220 Answers
The fuse is a we4x800. It is mounted on the heater housing on the back wall of the dryer.
Posted on Apr 30, 2013
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: have a GE Dryer model DCL333EAOWW that will not
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 06, 2011
TheMobilian
  • 8220 Answers
SOURCE: Dryer model DBSR453EB1WW won't start.
8_29_2011_7_53_41_pm.jpgYou might have a tripped high limit. Looks like this.
Mounts on rear wall atop the heater element. If the dryer needs cleaning it someimes will overheat and trip this limit. I recently repaired one of these and made some PHOTOS
Posted on Aug 29, 2011
mechanicsonl
  • 431 Answers
SOURCE: my ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Posted on Jan 06, 2012
SOURCE: ge dsxh43eaoww won't start or anything, light on when open door, i have 240v coming in what's else can i check ?
I would start with your door switch it will not operate with this bad. Remember to rate my solution and give testimonial it is how i earn my achievements Thanks in advance.
Posted on Apr 24, 2012
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
My microwave won't heat
The real clue here is strangely enough the table not turning.
All units have a switch in the side (usually the right side) of the cabinet--when door is opened it allows the unit to work but will not heat or the table (usually both) will not work.
It has to be got at from the inside of the unit--little plastic holder with the switch which looks like a leaf switch.
What I have seen several times (including a unit I own) is that from countless opening and closing the door the holder may break or even melt and the contacts on the switch no longer are in position to work when door is open.
The purpose of such a switch is simple---it prevents the unit from being used if the door is OPEN.
Not a hard or expensive repair
Dec 06, 2012 | GE Profile Spacemaker XL 1800 36"...
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
heatman101
Sep 19, 2011 | Kenmore Dryers
Where my clock was on my stove a E1 F-5 came up and my oven won't work now. The top burners are working but the oven won't. We don't have a manual for troubleshooting. Can you help me?...
F5 - E1 Self clean latch will not lock
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlkkZwU
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlaiwL3
Sep 04, 2011 | Kitchen Ranges
Hi. My GE Triton Dishwasher GSD5500G01WW is dead. No lights or anything. I checked the breaker. It was fine. Any ideas?
hello there and welcome to fixya
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Aug 22, 2011 | GE 24 in. GSD6660GSS Built-in Dishwasher
The door keeps saying it is open and i replaced the door sensers but its not that can you help
Hello melvin... When the light stays on it usually means a door is open or the switch on a door or liftgate/trunk is bad. If the door adjar button is seperate from the latch assembly I pull the switch from the body and jump it out. Go one by one and you will find the failed switch. If the switches check ok and the connector is jumped and the light is still on then there is an open in the wires for the door ajar switch
Here are more procedures for troubleshooting...
Possible causes are :
1. Door switches stuck in closed position. Remove the rubber cover and loosen the screw holding the door switch. Pull out switch and check if the light stays on....if light remains on, fault is not with switches.
2. Anti-theft system ECU shorted. One of the wire goes to the alarm control unit. Unplug the alarm unit, if equipped and test.
3. Shorted interior dome light. If dome light is not working in the door ajar mode, remove the dome light and unplug the connector. If indicator light does not go off, fault is not with dome light.
4. Shorted Red/White wire. This would be the most difficult to diagnose as the shorting can be anywhere between the door switches to the indicator light. If you had done any wiring repairs prior to this happening, backtrack to check if any part of the wire is exposed and grounding
Good luck...i hope this helps.
Jul 17, 2011 | Renault Sport Cars & Trucks
The open door light on the dashboard won't go off and the dome light stays on 2001 Sub For. All doors are in fact closed.
Posibly a short in the wiring from a door switch. Try each one with the rest of the doors closed until you find it. You should be able to remove the switches from the door pillars.
Jun 28, 2011 | 2001 Subaru Forester
GE DCSR483EA Electric Dryer Logo
89 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
