My hot tub moter makes weird sounds pleas help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
More than likely you have a leaky wet end seal that has rusted the drive shaft of the motor. There are replacement seal kits available but more than likely the bearings are bad and your pump needs to be replaced. If I'm correct the noise will get louder and louder until the pump seizes.
Posted on May 09, 2013
Halo there n overheating problem on my 200sx det i have replaced the moter replaced the radiator to n twin core new water pump new thermostat and i fitted 2 12' electric fans i drive about 15min and it...
When the car overheats be sure to check all pipes are hot if some pipes are cold there might be a air lock which stops the circulation are the car heaters blowing hot air ?if the rad ain't hot then those fans not going to do much good if everything is hot are the fans working ? Is it a faulty reading from the engine coolant sensor ? And don't rule out faulty new stuff I've had lots of faulty new stuff remove the thermostat to rule that out .
Feb 08, 2015 | Cars & Trucks
Tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
What causes my jacuzzi hot tub to turn itself on.
sounds like you have an electronic system that operates the tub. Many times those get hit with a voltage spike and it burns up a relay on the circuit board and THAT is what make them come on at weird times.
You will most likely need a new control for your tub.
Jan 04, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Apr 14, 2010 | Pool & Spa
1994 chevy s10 .. moter swapped to carburated and
Actually, I recommend putting an after-market ratchet shifter on the transmission. This sounds weird, but we purposely cut the TPS out of my TH350 for street / strip racing. A ratchet B&M shifter or something similar will work, but it makes destination driving (I.E groceries, family, etc) a bit more of a pain.
Nov 06, 2009 | 1994 Chevrolet S-10
Amana washer not agitating, moter spinns fine
Well at least you know your motor works. your motor is connected to the tub and transmission with a coupler actually I believe its two of them one is probably broke
Sep 03, 2009 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
