Question about Radio Communications
I have a yaesu 1500m radio will receiver but when I push button on mic to transmit error shows up on screen what could be the problem
    Master:
  • 623 Answers
It's probably set to a frequency that is out of the pre-programmed band limits.
Posted on Nov 05, 2013
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
Neto
  • 123 Answers
SOURCE: Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Posted on Jan 23, 2009
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: Yaesu Ft-60R with Kenwood TK-3107
ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Posted on Feb 27, 2010
SOURCE: ICOM IC-A23 CL-ERR Problem
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
DO NOT GO BUY ONE FOR 23 BUCKS PLUS SHIPPING!!!!!!!
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input.
You either have one or know someone who does that you can borrow.
If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off.
Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on.
They should say "clone".
Now press the" ENT" on the good radio,
This will send the data over to the "bad" radio.
Now turn them both off, remove the cloning cable and turn them back on.
Both should be working now.
\WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells.
Some times this can extend the battery's life.
Good luck!!
Rich
Posted on Sep 12, 2011
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Yaesu 1500m locks up can't on one channel. Can't shut off
Remove the battery and insert again. Reprogramme the Radio and check it will work. Also disable the key by which you use for lock the channel.
Jul 20, 2015 | Yaesu Radio Communications
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
Radio model 1500m yaesu nessecito parter nuber micro processador hd5473877h ou tecnical manual obrigado
You require a user manual for your Yaesu 1500m.
Try this: join yahoo group SPECIFIC to your radio Make/Model, you will receive great information and you can download manuals, diagrams and other goodies for your radio, if available and all this is free.
I hope i have assisted you with your query.
Regards,
Peter
Nov 25, 2012 | Radio Communications
Hello i have a yaesu ft-2900 it receives just fine but when i transmit it shows error. this radio is brandnew
Hi Gerald,
When you say you used the software to download frequencies, do you mean as in from the internet, or did you have to input frequencies via the software on your PC?
There is a difference, that's the reason I ask.
If, by using the software you manually input the frequencies, then did you input both the output and input frequencies or just output for each channel?
If the latter is true, and you are trying to access another user via a repeater, then that is the error.
Repeaters generally, require both the input frequency = the frequency you transmit on, and the output = the frequency you receive on.
Without both frequency pair, you won't be getting out, and no won can hear you, as you are basically transmitting as a simplex station on a repeater allocatted channel, hence the error message on your display.
The radio you have is used by many amateurs & CB operators, and both group utilise repeaters within their allocated spectrum, excluding 27 meg CB, which is simplex only, but with SSB included.
I hope this answers your query.
Best regards,
Peter
Nov 28, 2011 | Yaesu Radio Communications
Yaesu FT 2400. Will transmit but no audio. I am told the mike is probably the problem. Tried to locate a replacement mike with no success.
TWO questions:
KG6OFD HERE.
IT IS 4 PIN MIC?
HAVE YOU TRIED YAESU OR HAM RADIO OUTLET ONLINE?
SD TECH
Dec 31, 2009 | Car Audio & Video
Radio Communications Logo
76 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
