Question about Dryers
Not working I do at least 1 load of laundry every day. Yesterday I put cloths in and it just wont turn on. I just dont know what to check? please Help, I sure dont have the money to call anyone
  • Dryers Master
  • 8,220 Answers
Look at the vent and see if it might be clogged. If it is you prob need to clean the whole machine and then replace the fuse which on the blower on most dryers.
Posted on May 01, 2013
muttandjeff
  • 359 Answers
SOURCE: my dryer doesnt work
check the door swich to be sure made up properly
Posted on Dec 30, 2008
vanni7
  • 163 Answers
SOURCE: dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Posted on Jan 04, 2009
SOURCE: Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Posted on Jan 05, 2009
  • 686 Answers
SOURCE: Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Posted on Mar 01, 2009
  • 415 Answers
SOURCE: dryer not heating timer making clicking sound but
then check the thermal fuse again, but b4 you replace ohm it and check it the vent is generally plugged when something such as this occurs check the airflow outside the home- do you feel air if not the vent is plugged with something if you do feel air good flow then is the vent behind the dryer getting crushed or pushed back too far against the wall?
Posted on Sep 01, 2009
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
I put on a regular load of laundry and the machine
Broken or clogged yes, as long as the timer and electronics are not an issue.
Apr 18, 2010 | Whirlpool LSR5132PQ Top Load Washer
Smelly washer
The disgusting smell is from using too much detergent, using softener or from using only cold water for washing.
The area of buildup is just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area: http://www.youtube.com/watch?v=Ua6OJPn0-fU
The added bulk of the laundry will raise the water level to include the "splash area" intermittent pausing to soak is also a good tip in extreme cases.
Oct 01, 2009 | LG WM1812C Front Load Washer
Musty smell
Hey
try following tips:
  1. Check that the drain line is clear
  2. Check the drain hose for kinks or blockages
  3. Check pump for blockages
  4. Check for build up of soap in the outer tub
  5. Check for article of clothing stuck in the outer tub
please rate my suggestion...
May 21, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Apr 17, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Feb 06, 2009 | Whirlpool Washing Machines
Kenmore front load washer 417-44082400
Check your ettings
one of them has been changed
try using different settings till you get the right one back
otherwise your timer my be malfunctioning
Jan 18, 2009 | Washing Machines
Washing machine woes
Buy a new machine. You have used it well. After Two repairs I suggest replacements
Since you are not paying for water I would suggest a top loader. I have been Happy with Kenmore (Whirlpool in Kenmore skin) or look at a Speed Queen Top loader.
Dont over load your new machine, learn what it can and cant handle.
Best of Luck T
May 28, 2008 | Whirlpool LSR7333 Top Load Washer
Dryers Logo
Top Dryers Experts
