HP DC4000 (Q2125A#ABA) DVD±RW Burner Logo
A
Anonymous Posted on Apr 30, 2013
4000 dc liquitron manual - HP DC4000 (Q2125A#ABA) DVD±RW Burner
How do i power up my acer ferrari 4000
Remove main battery and try again, if nothing! check power adapter for correct voltage, If okay! sub out the ram memory one at a time and test, still no change! the DC jack is often the source of trouble and the laptop will need to be dismantled down to the motherboard level, the DC jack will probably need resoldering.
1helpful
I have a problem, my copier constantly displays the error E000748-4000 and asks for reboot. Could you please give me an explanation, can I fix it on myself? Thank you . Andrey
these error stands for DC controller pcb.
Few possible solutions:
  • TURN THE COPIER OFF AND ON
  • RECONNECT ALL CONNECTORS ON DC CONTROLLER AND OTHER PCB'S
  • REPLACE DC CONTROLLER PCB
If You want service manual write on [email protected]
PS reconnection of all pcb's usually helps!
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
CLC 4000 FUSER ERROR?
The problem is that the lower fusing roller has shorted out and it may have shorted out the DC- Controler. Did you resently replace the lower fixing lamp. If yes it is wise to replace the dc- controler at the same time. A suggestion from a Canon tech pub... Good Luck....
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
