Question about Maytag Dishwashers
Maytag quiet series 300
My glasswear has gritty residue on it after running through a wash cycle. I've tried different detergents and rinse aids and nothing helps. I've even washed my dishes by hand then ran them through a wash cycle and they still come out dirty. What is the problem?
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Fine particles of food/grit left at end of cycle
Open the door and check it with a level. If the dishwasher isn't perfectly level, turn its feet (behind cover at floor) until it is level. If the jet bars can be removed, take them off and rinse them out. Make sure they're engaging with the pump outlet properly. There may be a plastic bushing that the main wash arms rotate on. If this is worn, replace it. It will make a world of difference. Finally, make sure you're using enough detergent. I suggest the cheap powdered type. It seems to have the best cleaning ability. Finally, make sure the rinse aid dispenser is set to dispense enough.
Jan 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
19 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
