Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Off balance cabrio!
My washing machine keeps getting off balance with every cycle it goes thru. So they said I needed a new electronic board and that would solve the problem. 1 new board and 420.00 dollars later for the board and install and it's still doing the same thing!!! Please help!! They said electronic parts are non returnable.
    President:
  • Whirlpool Master
  • 662 Answers
Check your 4 struts, you only had to re-fix your load when it became unbalanced. Better still check on 'youtube' with brand model for solutions. There are possibilities for re-selling the board. Hope this helps......
Posted on Apr 30, 2013
SearsTechToo
  • 261 Answers
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Posted on Nov 01, 2008
  • 240 Answers
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
  • 1531 Answers
SOURCE: Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Posted on Jan 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Washing Machine shows error code C1
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
richroth
  • 9472 Answers
SOURCE: my whirlpool cabrio washing machine keeps giving
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Posted on Jan 05, 2011
My Roper washing machine keeps filling and draining in the final rinse cycle.The lid lock light flashes and the machine will not complete the wash cycle, just keeps filling, spinning and draining!
Depending on your model, it will either have an electronic or mechanical timer. If electronic which it sounds like, you likely have a bad board or control unit. If mechanical you will need a new timer.
My old washer was mechanical and I had to replace the timer several times over 18 years. My new Samsung is all digital so when it goes bad, will have to diagnose the circuit that needs replacing. Normally there is an error code on the LCD readout.
Mar 20, 2016 | Roper Washing Machines
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
My washer keeps stopping at the spin cycle and says UL for uneven load. The load is not uneven and evey load does this
Hi.
UL is displayed when there is a balancing problem or when balancing sensor is defective.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual also try distributing the load
. If that does not work there are internal faults that may trigger the fault code. The balancing sensor and the electronic control board must be tested. The machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Jul 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
