Question about Saws
De walt dc385
How I remove broken saw blade on this dewalt d&c 385 cordless?
  • 25 Answers
Should come with a chuck key, or a key to lossen the blade. all of them lock in this manner regardless of manufacture. Check website of manufacture for this, or your mannal
good luck
Posted on Apr 30, 2013
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
Posted on Aug 10, 2009
  • 94 Answers
SOURCE: clamping a blade in the saw
it's either a cylinder behind fence,twist it to open,let go so it close's. or there is a lever on the side that you lift up to insert blade let down to hold in place
Posted on Apr 21, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Dewalt DC385 Reciprocating saw, when I
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
Posted on May 24, 2011
SOURCE: The blade is stuck in
The chuck may just be sticking. Remove the front housing with the large screw, tap the chuck with a hammer & pin, and lube.
Posted on Apr 01, 2012
SOURCE: I Have a Dewalt DC385 type 2 Reciprocating saw.
REMOVE THE BLADE !!!! take the handle apart and lift out the switch. keep track of the lock slide button and how it is installed. unplug the switch wires. carefully touch the wires you just unplugged onto the battery terminals. these wires lead directly to the motor. BEWARE.. if the motor components are good , the saw will run at FULL SPEED. you only need to tap the wires, DO NOT jamb them onto the battery. If the motor runs then most likely the switch is bad. If you know how to use a continuity tester then you can also check the switch. Bad moter likely culprtet is the brushes are crapped out.
Posted on Apr 04, 2009
The shaft rusted and does not hold the blade; how do I remove the rubber cowling to repair / replace the shaft?
Remove the 2 torx screws that hold the foot on the front of the tool - the boot will slide right off with the blade release lever.
DeWalt makes a shaft upgrade kit that is fairly easy to install.
Mar 08, 2015 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How do I get a broken blade out of Dewalt DC330?
Do the same procedure on how you installed the blade.
Sep 14, 2014 | Dewalt 18v 18 Volt Cordless Xrp Jig Saw...
How to grease dewalt dc385
The grease they recomend is part number 286436-00 at a cost of $80.87 for a 1pound can. I'd call the factory at 1-800-433-9258 and see if they offer a smaller tube.
Dec 20, 2012 | Dewalt Dc385 Xrp 18v Cordless Recip Saw...
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
Aug 19, 2012 | Dewalt 18v Dc385 Cordless Reciprocating...
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
May 23, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How do i CHANGE THE SAW BLADE
Hout40, holding saw as U would use it, is a "dog" on the right side, that U pull out.
If U turn it around and look at the other end ( with the blade end) U can see the "dog" work the inside, that releases the blade. HTH, JoeB
Feb 19, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
How to open the front housing of dewalt dc385 recipricating saw
press release button and remove shoe on front of saw. Remove 2 screws on front end. Slide off rubber covering. To open gearbox remove 4 screws and pull off. Note, once open yo probably have to replace the gasket. If saw is jammed, try spray a penetrating oil in and tap shaft with a hammer using a wood dowel for contact. You can remove the 2 rubber plugs from the gear casing and pump in grease without removing the cover.
Stephen Brown
Jun 13, 2010 | Dewalt DC385B 18v. Cordless Bare...
De Walt Power Shop DW125. Cutting problem.
Sounds like a dull blade or not enough teeth on the blade. Go with atleast 40 tooth.
Feb 02, 2010 | Dewalt Saws
I Have a Dewalt DC385 type 2 Reciprocating saw. I push the trigger and it does not work all of a sudden. Could the trigger unit be bad. How can I tell if it is bad, I just dont want to keep replacing...
Mar 12, 2009 | Dewalt DC385B 18v. Cordless Bare...
Saws Logo
444 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
