Installing 32 bit webtricity 2
It causes windows explorer to crash when trying to start install of webtricity.
  • Computers & ... Master
  • 16,589 Answers
Post the whole crash message.
Posted on May 06, 2013
SOURCE: Unable to Install INTERNET EXPLORER 7
try installing sp3 first available from microsoft as an update or a standalone downloadable iso file (burn iso to a disc).
cideria
Posted on Aug 14, 2009
  • 12 Answers
SOURCE: Internet Explorer 8 crashing when I login to facebook. Help pls!
Try checking what addons are running in IE, it could be a Software conflict , aslo update flash/java/shockwave
also, try loading the page through a proxy
https://cowclock.com
you can use the firstbar but it disables client side scripting
Glype works pretty well and CGI is java re-rewrighting
good luck!
Posted on Sep 04, 2009
  • 5 Answers
SOURCE: IE8 installation failed, and said that The
If you downloaded the 32 bit edition and you are running a 64 bit machine you need the 64 bit application, if you have a 32 bit machine and downloaded the 64 bit veriosn you need the 32 bit version.
Posted on Oct 07, 2010
  • 2291 Answers
first restart ur pc and then clean up ur registry and system with reginout , now install it , it will install and also update ur windows installer
Posted on Oct 08, 2010
  • 326 Answers
SOURCE: i tried to use the latest version of Internet
IE 9 is still in beta right now and probably won't work correctly with a starter version of Windows 7.
I'd suggest download Internet Explorer 8 from Mircosoft's website if you really want to use IE.
Although, I'd suggest Mozilla Firefox or Google Chrome as a better alternative to IE.
Posted on Mar 05, 2011
Everything is fine except for crashing (blue screen) or just blacking out. Can restart automatically or I have to remove the battery, power supply retry several times.
Hello the homepage is here:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/inspiron-1520
Windows 7 is not a supported system.
Especialy not the 64 bit. The 32 bit will probably work fine.
Try to install the newest graphic driver and upgade the bios to the latest version.
DO NOT run the bios upgrade before the system is running fine.
Install any missing drivers.
Look in the device manager.
Any file here from dell needs to be unziped before you install it.
Good luck
Nov 25, 2012 | Dell Inspiron 1520 Motherboard
I had a 32-bit webtricity 2 and other programs that are 32-bit, I have a computer with Windows 7 64-bit and having trouble installing these programs because during compatible with the 64-bit OS is there...
64 bit OS can run 32 bit software but if the software provider has a version for 64 bit it might require you to download this version ad prevent you from installing the 32 bit version.
Kind regards
Mar 06, 2011 | Computers & Internet
Can't install windows xp 64 it crashes at windows starting
Because you system is a 32 bit system you will have to install XP 32 bit. Then your problem will go away and you will be able to install Windows XP. Thanks for a good question others may also have some ideas. John
Feb 09, 2011 | Dell Precision T5500 PC Desktop
I haVE WINDOWS 7 HOME premium desk top and each day on certain web page using flash player 10 my internet explorer 8 shuts down saying a problem with web page caused internet explorer and windows to...
Is your system running 64-bit or 32-bit? To find this out, press "start", right click on "computer", then click "properties". There it will specify your "system type" (64-bit or 32-bit). There is no Flash Player for 64-bit Web Browswers available yet. If your computer is running 64-bit, you should try using the 32-bit Internet Explorer (can be found in your list of programs in the start menu).
Jan 08, 2011 | Microsoft Internet Explorer 8
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
I play a game on facebook, and every time I go into the game, a screen says my plugin has crashed. What do I do to fix it?
Depend on your OS. If is Windows IE, some issues has found on this.
Try this :
our version of Windows is either a 32-bit operating system or a 64-bit operating system. A 64-bit operating system can run both 32-bit applications and 64-bit applications.Your browser, such as Internet Explorer, is either a 32-bit application or a 64-bit application. Flash Player works only with a browser that is a 32-bit application. On a 32-bit operating system, your browser is always a 32-bit application. However, on a 64-bit operating system, your browser is either a 32-bit application or a 64-bit application. Make sure you are using a 32-bit browser by following these instructions:
Windows with Internet Explorer
To make sure you are using a 32-bit version of Internet Explorer, follow these steps:
  1. In Internet Explorer's Help menu, select Help > About Internet Explorer. (In some versions of Internet Explorer, select the question mark in the upper right corner to select About Internet Explorer).
  2. If you do not see the words "64-bit Edition" next to the version number, you are running a 32-bit version of Internet Explorer. Continue to Determine the Flash Player version you installed, if any.
  3. If you do see the words "64-bit Edition", go to Flash Player on 64-bit operating systems (TechNote 6b3af6c9) to continue troubleshooting your Flash Player installation.
Windows with other browsers, such as Firefox, Google Chrome, or Opera
No official 64-bit version of these browsers is currently available on 64-bit Windows operating systems. Therefore, unless you are using a test version of a browser (not typical), your browser is a 32-bit application, and therefore, works with Flash Player. Continue to Determine the Flash Player version you installed, if any.
2. Determine the Flash Player version you installed, if any
Before you troubleshoot Flash Player installation, determine the version of Flash Player you have installed, if any. You can see if it is working and whether it is the latest version available for your operating system. Follow these steps:
  1. Go to http://www.adobe.com/software/flash/about. If you have already successfully installed Flash Player, the page displays the Adobe Flash Player version as shown in the following image:
    Note: The version number in this example might be different than the version you have installed.
    If you have not successfully installed Flash Player, you will not see the image.
  1. The same page http://www.adobe.com/software/flash/about has a table that shows the latest Flash Player version available for your operating system (for example, Windows or Macintosh) and your browser (for example, Internet Explorer or Firefox). If the version information shown in step 1 does not match the latest version shown in the table, upgrade to the latest version. To upgrade, continue to Uninstall previous versions of Flash Player.
Note:Internet Explorer uses a different Flash Player than other browsers such as Firefox or Google Chrome. Therefore, if you sometimes use Internet Explorer and sometimes use another browser, you might have installed a different version of Flash Player for Internet Explorer than for other browsers.
3. Uninstall previous versions of Flash Player
Before you install Flash Player for any Windows browser, uninstall all previous Flash Player versions and restart your computer. Follow these steps:
  1. Uninstall all previous Flash Player versions and restart your computer. For Flash Player uninstall instructions, see Uninstall Flash Player (TechNote tn_14157).
  2. Restart your computer after uninstalling.
  3. If you are using Internet Explorer, continue to Verify Internet Explorer security and ActiveX settings. Otherwise, continue to Download and install Adobe Flash Player.
4. Verify Internet Explorer security and ActiveX settings (skip for other browsers)
Make sure that Internet Explorer security default level is set to Medium. This level allows viewing ActiveX controls, such as Flash Player. To set browser security to Medium, perform the following steps:
  1. Open Internet Explorer.
  2. Choose Tools > Internet Options.
  3. Select the Security tab.
  4. Select Trusted Sites zone.
  5. Select the Default Level button. (If the Default Level button is dimmed, continue to the next step).
  6. Move the slider until the security level is Medium.
  7. Select Apply.
  8. Select the Internet zone.
  9. Repeat steps 5 - 7. When done, select OK.
Oct 04, 2010 | Adobe Computers & Internet
Adobe reader won't work on 64 bit system
Download Install Adobe Reader 9.3.3 @ http://get2.adobe.com/reader/
For Windows
•Intel® 1.3 GHz processor or equivalent
•Microsoft® Windows® 2000 with Service Pack 4, Windows Server® 2003, 2008 and 2008 R2; Windows XP® Professional, Home Edition, or Tablet PC Edition with Service Pack 2 or 3 (32-bit and 64-bit); Windows Vista® Home Basic, Home Premium, Business, Ultimate, or Enterprise Service Pack 1 or 2 (32-bit and 64-bit), Microsoft Windows 7 Starter, Home Premium, Professional, Ultimate or Enterprise (32-bit and 64-bit)
•128MB of RAM (256MB recommended)
•335MB of available hard disk space (additional space required for installation)
•Microsoft Internet Explorer 6.0, 6.0 with Service Pack 1, 7.0 or 8.0, Firefox 2.0, 3.0, 3.5 or 3.6
Hope it helps.
Aug 09, 2010 | Microsoft Internet Explorer 8
After adding a network printer which is on a Windows 7 computer - on a XP computer it is possible to open the printer but printing test page crashes windows explorer
Check your installed print server software for 32-bit and 64-bit versions. Both versions need to be on the machine that is directly connected to the printer, if you have a mix of the two types of Operating systems. 32-bit XP is very common and Win7 64-bit is becoming widespread.
(For HP printers using the manufacturer's UDP software, I found that if the printer was installed directly on a 64-bit Win7 machine, it failed. After installing the 32-bit software version in addition to the 64-bit, all the problems went away.) At least with the HP software, we did have a few minutes of confusion trying to find where the driver actually ended up. Double-clicking the downloaded file unpacked the drivers but didn't install them at the same time.
I hope this helps.
(obviously there are no firewall problems. I'll also assume the printer drivers were loaded without a problem on the two individual machines. This may have meant connecting it to the XP computer for a few minutes via the USB cable with some printers; consult your manual or the online support for the model.)
Feb 08, 2010 | Office Equipment & Supplies
IE 32-bit browser need to run on my 64-bit browser
Hi buddy323,
You will find the 32 bit browser on your Vista installation disk. Or your restore CD from Dell.
If you can't find it there, you can download it HERE. Or may want to go for the IE version 8.
Good Luck and don't forget to leave a rating.
Thanks Mark
May 01, 2009 | Dell Inspiron 530s Desktop Computer...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
