Question about Lutron Electronics Toggler Preset Dimmer, White #TG600PH-WH
WHEN ON DIM THE LIGHT FLICKERS - Lutron Electronics Toggler Preset Dimmer, White #TG600PH-WH
  • 2,113 Answers
That is because the dimmer is designed for incondescent lights and you are using compact fluorescent. To solve the flickering problem add at least one regular bulb to the system. If there is only one bulb then replace with a regular bulb if you are using a dimmer.
Posted on Nov 21, 2013
4x4 light flickers,light dim or not there at all. will not engage if not lit up.
if it is lifted it may not be engaging all the way may have to check the rod and make sure it is going into 4X4 all the way
Dec 17, 2012 | 1998 Chevrolet Chevrolet silverado
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
When I turn the light on it doesn't dim at all, and when the dimmer is at full power it flickers non stop. What is the solution?
Switch the hot wire and the wire going to the light around... you are wired basackwards...
heatman101
Apr 29, 2011 | Leviton Decora Light Dimmer Switch
It flickers periodically from light to dim
You may have a problem with the screen's back light. It could be a ballast that may go bad or the light itself may go bad or loose connections in those areas may cause it. Check as well the data cable or check if a different cable would work.
Oct 06, 2009 | HP Pavilion F50 17" Flat Panel LCD Monitor
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Ds lite bottom screen
Could be the back light.Probably need to replace it.They are reasonably cheap.
Jul 01, 2008 | Nintendo DS Lite Console
Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Apr 09, 2008 | Televison & Video
Lutron Electronics Toggler Preset Dimmer, White #TG600PH-WH Logo
146 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
