Question about Compaq Presario V3500 Series Laptop AC Adapter 18.5v 3.5A (AC11VPN4C9VA7)
Hp hard drive error code 7
Unable to boot . getting hard drive error code 7
  • Compaq Master
  • 7,627 Answers
I have win 7 on hp elitebook 8530p and i got the 0xc000000e error and i changed my boot order and i still cant boot from my cd rom
If you take the hard drive out, can the laptop boot from its DVD drive? If the laptop can boot up from DVD drive, then you need to reformat the hard drive before you install the Windows 7 using your DVD drive.
Mar 01, 2014 | HP EliteBook 8530p Notebook
Error code OX45d and the ASUS boot disk can not finish fresh install.
Your hard drive has some bad sectors and Windows 7/8 does not want to be installed in the problematic hard drive. They are require a healthy hard drive.
Feb 14, 2014 | ASUS Computers & Internet
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
Insert boot disc error on hp pavillion a622n
Boot disc error indicates that your computer is unable find any Operating system to boot up. Go to BIOS settings and figure out if your BIOS detects your hard drive. If so, format your hard drive and install an operating system.
I would love to hear from you in regards to this concern.
Sep 07, 2012 | HP Pavilion a1310n PC Desktop
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
DELL 5150 hard drive error 7
Error code 7 means that your hard disk drive failed and is defective. As for reloading windows XP, I wouldn't. It's not supported by Microsoft any more. I would load Win 7 after replaceing the drive.
Feb 20, 2012 | Dell Dimension Computers & Internet
LapTop Dell N1050 Windows 7 64 Error code: 0151 Msg: Hard Drive 0 - incorrect status: No additional sense information
It appears that you have a hard disk (drive C:) drive failure. If you can boot the laptop from a CD then you need to have the hard disk drive replaced. You should have a CD that came with the computerthat has "Diagnostics and Utilities" listed under contents. You can boot from this CD.
Jul 02, 2011 | Computers & Internet
Blue Screen Error Windows 7 Dual boot config: stop: 0x0000007e (0xFFFFFFFFC0000005, 0XFFFFF80002EE4338, 0xfffff8802fc4838, 0xfffff88002fc4OAD) I have a Hp pavilion dv-7 1020us laptop, getting a blue screen...
If have Bootable windows 7 install it .
Installation guide WIN XP http://www.windowsreinstall.com/articles/bios/ http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx VISTA http://vistaultimate.windowsreinstall.com/repairstartup/repairstartup.htmHope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Computers & Internet
Trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and...
According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
  1. Use the partition command to remove the target partition from the drive to wipe this out
  2. Partition the now unused space and reformat (again!), and
  3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
Dec 26, 2010 | Western Digital WD Scorpio Black...
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Compaq Presario V3500 Series Laptop AC Adapter 18.5v 3.5A (AC11VPN4C9VA7) Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
