Question about Autel MaxiScan MS509 OBD-II-EOBD Scanner MS509
Software update scanners
Usb driver wont load
I have purchased a second hand mustek A3 usb scanner, it powers up but wont scan. I have downloaded the drivers from Mustek. When I click on the direct scan icon on my desktop it opens the programme but...
When is tah last time you can scan with your scanner? You can always try to uninstall and reinstall the software of the scanner to fix the problem with scanning. and if there is an available update for teh software or firmware of teh device try to do so. ok?.
Cheers!!
Aug 25, 2010 | Mustek A3 USB Flatbed Scanner
Have HP scanjet loaded software and driver but it just does not work checked electrical connection and usb ok thought it had gone wrong so bought new HP g2410 still cannot load checked hardware manager...
Having re-read your post it seems you have a visioneer scanner and installed HP scanjet drivers so this would definitely be an issue.
Ok, unplug usb lead between scanner and pc.
go into add/remove programs and remove any scanner software that may be showing.
load correct scanner driver (preferably the latest version from the manufacturers website).
plug in scanner usb lead when prompted and turn scanner power on.
It should then install correctly.
If usb stuff starts playing up it's usually easier to unplug it, uninstall it then re-install it using the latest drivers from the manufacturers' website. Don't just stick the disc in and re-install. Can save hours of messing about.
Apr 28, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Jan 26, 2010 | Visioneer OneTouch 5820 Flatbed Scanner
I can not scan using my HP color laserjet 2840
Hello, wmpinc1
Sometimes what happens is that the software installed on your computer, relating to the printer will become sort of confused. Re-install the software after a quick un-install of the same software. You can get the software from either a disc or from the Web Site of the scanners manufacturer.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the version of the operating system you own. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, an reconnecting the power and USB cables. Check the operation of the scanner table itself.
Verify that there is nothing wrong with the light bulb belonging to the scanner. To do this have the cover up of the scanner table (if there is a cover) and press scan button, the program should initialized on your desktop, the the light should turn on (look for a light turnning on) and after a few seconds (or more) somethiing should start moving indicating the scanner is working properly. If you think the scanner is defective contact HP.
Good luck, jasahasch
Aug 13, 2009 | HP LaserJet 2840 All-In-One Printer
TROUBLESHOOT
Hiya... Try reinstalling software for scanner again .. and a differnet USB cable.... d/load a driver update for it ..if necessary ..
should sort it... make sure you follow the cable and power up instructions exactly ..
Regards Faggly
Mar 26, 2008 | HP Scanjet 4670
Mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Feb 07, 2008 | Mustek A3 USB Flatbed Scanner
Wont load into computer
vuescan you may be required to purtchase a software licence however your scanner will work with this software in vista you will have to manualy install the driver it will be located in the directory c:\vuescan\ after you install the program you can get this program from http://www.hamrick.com/ it works with my 320u i had tro manualy install the driver though by going to device manager and selecting update driver and browse my computer for driver software place directory from above and hit next.
Jan 21, 2008 | AcerScan 320U Flatbed Scanner
Installation problems
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Nov 29, 2007 | Mustek A3 USB Flatbed Scanner
Software wont load or install
what error you getting first install the software then connect the usb cable of scanner.
bye
Apr 12, 2007 | Canon CanoScan 4200F Flatbed Scanner
Autel MaxiScan MS509 OBD-II-EOBD Scanner MS509 Logo
Top Autel Computers & Internet Experts
David Payne
David Payne
Are you an Autel Computer and Internet Expert? Answer questions, earn points and help others
