Affinity washer where can I get a door latch product number is 134766200-0606?
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
RixsFixes
  • 2200 Answers
SOURCE: what are parts numbers for frigidaire front load
Hi
The door latch Part 1191127 is at this link
http://www.repairclinic.com/Appliance-Parts?s=t-ATFB6000ESO-%3d%3dc226
Motor Control Board Part 1191307 here
http://www.repairclinic.com/Appliance-Parts?s=t-ATFB6000ESO-%3d%3dc212
Hope this helps. Please do rate this answer. Thanks.
Posted on Aug 13, 2009
Jahn27
  • 1554 Answers
SOURCE: Hi, I need a replacement
You are referring to the door strike (item 14 in the diagram) shown below which is actually part number 134456600.
Frigidaire Affinity ATF6000FS1 Cabinet and Door Parts Diagram
Posted on Aug 25, 2011
ginko
  • 19396 Answers
SOURCE: affinity model # LAFW7000LWO front
Hi.
When that happens you usually need to replace the door lock. The door switch can be tested reading impedance. To test the door switch disconnect its contacts. Disconnect power first. Set multimeter on impedance (Ohms) Touch the switch contacts with the multimeter probes. The multimeter must read zero or low impedance (a couple of Ohms) when door is closed, infinity (circuit open) when door is open.
Here diagrams for your appliance: LAA7000W0
Parts in Au and NZ are available here: APWagner Appliance Parts..
Call vendor to obtain parts in other locations.
Regards.
Ginko
Posted on Aug 31, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire Affinity ATF7000 installed new door switch now says cd
    The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
    Posted on Aug 24, 2012
    My affinity washer door wont close. Seems the door lock is not working or something is stopping the door from latching
    you may have broken off a piece of the latch
    (hook portion) either on the door or the receiver portion on the machine. check for diagrams online using model #
    Apr 04, 2016 | Frigidaire Affinity FAFW3577KW 3.5 Cu. Ft....
    Why does my Affinity washer flash on front and then won't run? Model FAFW3511KRo
    Good Afternoon Friend, that's a great question!
    Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on your washer. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further.
    Best of luck! - Z
    Jul 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Affinity washer no digital display
    Hi Friend, thank you for your post!
    It appears your Frigidaire washer has power, but has no display. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps! - Z
    Jun 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Atf7000fs1
    Hello Andrea, thank you for allowing me to assist you. Let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further. I hope this information helps in a small way.
    Aug 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
    Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
    Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
    Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Can I reverse the door on my new Frigidaire Affinity front loader?
    Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
    Sean
    Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
    The door hinge has been broken and have been having to lift up to close door, but the latch has finally broken and door will not shut now. whre can i get a new one?
    My recommendation: 1-800-FRIGIDA(like Frigidaire), have your model number ready,it can be found on the washer door opening(washer side). Good luck !
    Dec 20, 2009 | Frigidaire Affinity ATF7000EG
    My frigidaire affinity wont start
    May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Washing Machines Logo
    242 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
