Question about RIM Blackberry Playbook with 64GB Internal Memory Dualcore 1GHz Processor Tablet
My tablet quit, went black, when turned on, red blinking light followed by yellows
Im not sure it is RIM or not. model number is: RD121WW. WORKED GREAT THEN JUST WENT OFF. TRIED TO TURN IT BACK ON, RED LIGHT, AND GOES OFF. IF I HOLD IT DOWN, AFTER A BIT BLINKING YELLOWS THAN NOTHING AGAIN...
label_chick
  • 407 Answers
SOURCE: cant turn blackberry rim on
Have you tried to reset - Firstly try removing the battery for 30 seconds or so and reinsert and power on.
Secondly try resetting hold down the following keys for a couple of seconds. ALT+RIGHT SHIFT(CAP)+DELETE
Posted on Jun 01, 2009
SOURCE: RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Posted on Sep 06, 2009
  • 88 Answers
SOURCE: shut off
If the battery has gone flat before you started re-charging it, the phone has turned itself off.
Let it charge for 5 mins, then hold the red button down until you see it re-booting. You can use it while its charging.
Sometimes the cellular phone receiver does not come on when it reboots, if the battery isn't charged enough - when you make a phone call it will let you know and ask to turn on if the battery is charged enough.
Store it in the special holster it came bundled with - when you put the phone in the holster it has something that turns off the display to save battery (phone still on) and other useful things like activating vibrate mode.
Enjoy.
Posted on Sep 12, 2009
  • 846 Answers
SOURCE: doesn't turn on, Red LED light stays lit
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
Posted on Sep 26, 2009
closerfan
  • 49 Answers
SOURCE: blackberry shuts off and red light keeps flashing.
The flashing red light is telling you that the battery is almost drained down to capacity and that the phone must be plugged in now. When the charge is this low you are going to have to leave the phone recharge for at least 12 hours before trying to use it again. Once the phone is turned back on, the phone will reset itself. Good luck.
Posted on Mar 04, 2010
Daytek model dk-191 blinks yellow light then red
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Feb 21, 2013 | Televison & Video
Tip
Ps3 blinking yellow then red light
to fix the problem of the ps3 turning on blinking yellow then red is a HUGE step, i went on youtube and found this guy who seemed to know what he is doing. follow this link and more
http://www.youtube.com/watch?v=U70SgRDVcBo
otherwise just send to sony
on Apr 26, 2010 | Sony Playstation 3 (PS3) Console
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
When we turn it on it beeps and shuts right off. Red light blinks.
if it goes green then flashes yellow then turns red take a look at
quite a few have asked the same question
http://playstationlifestyle.net/forums/showthread.php?t=2376
it does work. ive used it on a number of ps3s.
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
My storm battery icon was yellow then went to all red. I have it turned off and charging right now and indicator light is blinking greenish red? Is there a problem or does it just need charged
Battery icon goes yellow when charge is low, red when about to go off, yes, that's OK. Recommend give it more time after all the bars are full-white, to trickle more into the battery. Lithium batteries don't seem to like being flattenend and left flat in my experience.
The light blinks for all sorts of things, might also have pending messages, etc. Can use the Storm OK while it's charging, just hold down red button to turn it on again.
After turning on, sometimes the cellular receiver does not turn on until battery is more charged. Wait 10 mins and then try to make a phone call, you may get a message saying it's off, do you want to turn the receiver on - just say yes.
That should keep you going. Nice phone.
Sep 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
TV screen went black/ red blinking light
LOOSE CONNECTIONS ON THE MAIN BOARD! OR CHECK FOR A YELLOW FLAT CAPACITOR IN THE FRONT OF THE MAIN BOARD NEAR THE CRT'S. BURN'T, PART VALUE, 1200PF-2KU
Mar 16, 2009 | Toshiba 50H81 50" Rear Projection...
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
No power
When I turn on the tv, there's the green light, that shows it's on, but it's blinking green and the screen is black
Jul 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Jun 27, 2008 | Sharp CV-P09FX Air Conditioner
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RIM Blackberry Playbook with 64GB Internal Memory Dualcore 1GHz Processor Tablet Logo
18 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
