Question about Garden
Yard works lawn mower
The handle assembly fastens to the mower by fitting over 2 studs. With the slightest flex, the handle holes slip off the studs. It's a very cheap design. Are there any easy fixes?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Drill the studs and install pin threw the holes
Posted on Jun 07, 2014
SOURCE: Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Posted on Mar 26, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
SOURCE: Wheels not working on yard man mower
I have a Yardman 21 in with a Honda 5.5 motor the choke well not stay engaged long enough to warm up the engine it slides away as soon as you start it .Any suggestings???????
Posted on Apr 22, 2010
  • 420 Answers
SOURCE: lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
Posted on Jun 01, 2010
Cable assembly details
is it the brake cable ? when you release it, it brakes the engine and stops running, make sure you zip tie the cable down securely to mower handle also.. try sears most of them are made by MTD
Jul 23, 2013 | Mtd 22" Yard Machine Push Mower
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
Mower blade is spinning loose is not connected to motor. did a stud brake cause not is tight
Don't ever run a mower with a loose blade. Most push mowers have a blade adapter that slips over the engine shaft and allows the fastening bolt (and it should be a special hardened one with 6 lines on the head of it) to thread into the end of the crankshaft. The adapter could have slipped and needs to be repositioned on the shaft so that the blade can be properly tightened.
May 07, 2011 | Kelty Yard King 21" Push Lawn Mower w/...
Where is the oil drain plug?
If you look under the mower, there will be a square hole that a socket wrench will fit into. It will either be 3/8 or 1/2. You put it in there and start to screw it out. Once loose, it will come right out. It is more than likely plastic.
Aug 03, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
MTD 46" Yard-Man Lawn Tractor battery connection problem!?
the battery for a garden tractor should have the holes already in it if not you can buy a clamp that you can use that has a hole for what you need. good luck
Apr 11, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Changing blades on lawn mower
Very first thing to do - - UNPLUG THE SPARK PLUG
Lean the mower backward on the handlebar (take off the bag if it has one) and hold it down with something heavy like a cement block, bucket of water, anything that will keep it from tipping back up on you. Get a small block of wood like a 2x4, or similar to block the blade from turning. Find a socket that fits the bolt or nut holding the blade. A socket is best as they can be quite tight and a wrench is likely to slip and ruin the shoulders on the fastener. Using a long handled ratchet or breaker bar, turn the fastener to the left (counter-clockwise) and unscrew it all the way. Install the new blade, with the beveled side of the cutting edge UP toward the bottom of the engine, in the opposite sequence that you took it off making sure that it is lined up centered. Tighten the fastener approximately 60 foot pounds again using the wood block to prevent it from turning
Sep 19, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
