Question about Lexmark P315 InkJet Photo Printer
Printer isn'treading card
I have a lexmark p315 printer. just yesterday i went to print and it isn't reading the card. ( a 216 ) anyway i cleaned it and the card but still to no avail. it keeps saying that error in reading and to insert correctly or that it is damaged. my computer reads it fine and thecamers reads it kay so what is the problem.
According to Lexmark's website, the printer will not read a memory card larger than 256MB. They specifically mentioned xD cards, but not cover the other types of cards. I have a 512MB SD card, and had the same problem, so I would guess it can't read anything over 256.
Posted on Aug 22, 2007
  • 390 Answers
Has it done this before or is it a new issue, ie have you successfully read from this card before to the printer. Sometimes a card can be incompatable with certain types of printers. Check manual to see if compatable. If it has read it before, you may need to completely unplug all usb cables and cords after switching unit off and replugging to reset printer. Make sure all print queues are cancelled. Try again. If no better,try uninstalling and reinstalling printer.
Posted on Aug 12, 2007
  • Geraldine Watts Aug 28, 2007
    hatinLexmark seems to be correct if other solutions did not help. Sometimes certain printers are not compatible with certain softwares. The solution obviously to obtain a compatible card, or try to obatin compatible drivers from manufacturers site and try this. Did you try unisntalling driver for it and reinstalling it (the card) most software has drivers. Good luck.
I have this printer for years and it says ing it can not read card or inserted incorrectly i know that isnot the fact so what kind of card do i need
Did you try turn off the printer, then take out the memory card, check it for damage, put it back in and turn on the printer?
Here is a link to the manual in english. Try go to the Troubleshooting section.
Mar 03, 2016 | Lexmark P315 InkJet Photo Printer
Where can i buy compatable sd card for lexmark p315
SD cards should be available at just about any department, electronics, or office-supply store.
May 25, 2014 | Lexmark P315 InkJet Photo Printer
Printer will not recognise camera memory card hp p315 photo printer
Was your Lexmark P315 printer able to detect this particular memory card before? Try to re-insert the card - it could be due to a slight communication problem. Have you tried inserting a different known working compatible memory card into the printer's card slot? This could be due to faulty memory card.
Also, please refer to Memory Cards Supported by the Lexmark P315 Photo Jetprinter.
Jul 26, 2011 | Lexmark P315 Photo Printer with 2.5" LCD...
Hello,I haven't been able to use my printer for some time and the ink heads are blocked,can you help please?
To clean the cartridge via the operator panel, follow the steps below:
  1. Press the Menu button once. The Photo Menu will appear.
  2. Press the down arrow until Clean Cartridge (Press SELECT) appears.
  3. Press Select to begin the cleaning process.
  4. When the page has finished printing, press Stop/Clear to exit the Photo Menu.
However, if you have made several tries already yet cartridges are still not printing properly, it may be time for you to replace those old cartridges with new ones.
Source: How to Clean the Cartridge on a Lexmark P315 Photo Jetprinter
May 30, 2011 | Lexmark P315 InkJet Photo Printer
Jammed cartridge in Lexmark P315 photo printer
You may slide the cartridge.Its ok to do that, just slide to ur right.
May 28, 2009 | Lexmark P315 Photo Printer with 2.5" LCD...
P315 print cartrige error
What we surmised is that the little wire contacts on the print cartridge were bad. One suggestion was to use a pencil eraser over the area where the small wire dots are on the cartridge, then wipe clean with a lint free cloth. That didn't work either so I exchanged the cartridge and the problem went away.
May 14, 2009 | Lexmark P315 InkJet Photo Printer
Lexmark P315 connecting to Fujitsu Finepix S5100 Digital Camera
I belive Lexmark P315 only accept 256 mb cards at the largest
Dec 13, 2007 | Lexmark P315 InkJet Photo Printer
Lexmark p315
You mention two problems, are they both still active? The memory card issue could be a defective card; I've had brand new cards not work a number of times. It could also be a defective card reader in the printer but its more likely the memory card may simply need to be re-formatted. - Save any pictures you may have on the card to your PC if you need to keep them. - Format the card using the camera utilities. Do not use the computer to perform the format. - Try it again. If formatting the card doesn?t do it you might try another card you know works. If it does work in your printer then its probably the card, if not that strongly suggest the printer card reader is at fault. Let us know if you have any other questions and please don?t forget to rate this posting.
Feb 06, 2007 | Lexmark P315 InkJet Photo Printer
Lexmark P315 InkJet Photo Printer Logo
478 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
