Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
HDMI to VGA
How do I get my PS3 to hook up to a computer moniter I've already tried the sync button with the power... The moniter is supposed to be digital. when i turn it on it says Digital input self test feature check... and if you push the menu button it says auto detect Digital then it says analog input... but that's not right Input My cable is HDMI to VGA. it is a DELL moniter, I know it works and is not shot.
    Top Expert:
  • Sharp Master
  • 75,571 Answers
You need a video format converter to connect in between.
Posted on Apr 30, 2013
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
SD Tech
  • 14553 Answers
SOURCE: My Sharp Aquos LCD TV 40E77U is working on the analog input but won't detect HDMI inputs?
This set MAY require or have available a software upgrade for this issue.
Contact Sharp to see if they have it or if this is an issue in their database that is common.
Posted on Mar 21, 2012
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
I have a Toshiba 40"
ok if you go to your ps3 video settings you can change the out put from coaxial to hdmi. and you have to have both wires conected at the same time . go to ps3 video sttings change the settings to hdmi then on your tv change the input to the hdmi port you are using then confirm the change and save.. i hope that helps :)
Sep 20, 2011 | Televison & Video
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
How do I hook up the moniter to the CPU?
First figure out what output video the computer has. These days it can be VGA, DVI, or HDMI. Then determine what video inputs are on the monitor (same list). Then plug in the desired cable. Many monitors only come with the VGA cable. If you do not have a VGA port on the computer you would need a DVI to VGA adapter to use that cable. Otherwise buy the DVI or HDMI cable. (DVI to HDMI cables exist if you have HDMI but no DVI on the monitor and only DVI on the computer. However, you need to check your video specs closely. A Single link DVI is different than Dual-link DVI and the cables are not interchangeable.)
Once the data and power cords are plugged in, power up the monitor and then the computer. The computer should find the new hardware and install (or ask for a disc to install) the drivers.
I hope this helps.
Mar 20, 2010 | Gateway Computers & Internet
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
