What causes the toshiba dvd vcr combo to start playing for five seconds and then quit and power down
  • 3 Answers
If it happens only when trying to play tapes, suspect tape lacing belt, a bad idler/clutch or capstan belt. Also, I have seen a counter belt do this as well on some machines.
Posted on Jun 28, 2013
SOURCE: DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
Posted on Oct 04, 2008
SOURCE: Samsung dvd/vcr combo, dvd says "no signal," was working, vcr wor
On the remote, clicked a botton on the bottom. Don't have it with me so can't remember which one. Will look and post answer. Thanks
Posted on Dec 08, 2008
kala
  • 156 Answers
SOURCE: vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Posted on Sep 28, 2009
SOURCE: SV2000 DVD/VCR player CSV 205DT - power shuts off after 10 second
Mine does the same thing! Except it only happens when i try to use the VCR part. DVD works fine! Still looking for a code tho!
Posted on Dec 01, 2009
SOURCE: Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
Posted on Jun 10, 2010
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Have the insignia DVD/VCR combo but after a few minutes or watching a DVD it starts to skip like four or five seconds of the movie then it starts to skip every second and then finally it freezes. Even if...
Hello
Its laser Picku Unit is faulty. Either it may be dirty, or its laser beam intensity has sent down. Just put a cleaning disc, and play it for atleast three times. If this helps you, you can understand that the lens of the laser assembly was dirty. If this also doesn't help you, repace the laser assembly with same type and number is the only remedy. OK.
Apr 30, 2011 | Insignia IS-DVD040924 DVD Player/VCR
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Magnavox vcr/dvd combo--dvd's play about 1/3 of the way then quit
sounds like bad pick-up unit (optical eye). these will heat up and reduce the fm envelope signal causing the optical eye to not read disc info. not worth repair. (it may could use cleaning, but usually a dirty eye will effect the movies from the beginning not after warm-up. mch
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba MW20FM1 DVD section quits
am toshiba authorized servicer-have same model in shop for same problem-dvd board is defective-new board is about 290 from toshiba america parts-tv is actually made by orion with toshiba name stuck on outside-orion is junk-cost more than new set to fix-junk it and buy a panasonic-so far they still make their oun stuff
Mar 11, 2008 | Toshiba MW20FM1 20 in. Combo
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Locked DVD/VCR Combo
Hold the power button down for 5 seconds fixed it for me.
Sep 23, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
