Question about Samsung UN55B6000 54.6 in. LCD HDTV
Service manual un40d5500 - Samsung UN55B6000 54.6 in. LCD HDTV
Hello, where I can buy a Main board for a samsung led tv UN40D5500? Thanks.
Tv's parts vary in price and many of the main boards on them are not just snap in parts. They require many wires to be diconnected and some even require soldering. I apologize for no price answer but want you to know what you might want to look into. If you do it yourself it could be anywhere from $75.00 - 150.00. For the part. If you choose to take it somewhere, make it the trash or try to sell cheap, as is. Someone may be willing to take the burden. Remember the old tv's? Family would hand em down for 20 years. They last about 3 yrs now...if you're lucky.
Nov 03, 2016 | Samsung Televison & Video
Hello, my samsung tv is turned on and off continuously. Any idea what it could be? the model is UN40D5500. Thanks
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Samsung led tv won't power on - red power light is flashing
check the conections between psu and led bars,if the problem still,then the problem is in the led bar board.
Aug 22, 2014 | Samsung UN40D5500 40" 1080p LED TV - Ultra...
How to reset un40d5500
To do a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 13, 2014 | Televison & Video
Red light blinks
The TV Is 'thinking', be patient it should tur off soon.
if no, try unplugging the TV to reboot it and then plug back in after 60 seconds.
Nov 09, 2013 | Samsung 40 UN40D5500 TV
Red light blinks
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
How can I off the 3d effect in my Samsung led UN40D5500
When I looked at the specifications for the UN40D5500, that TV doesn't have a 3D video option. It does allow for 3D audio on the digital audio signal. The UN40D5550 has 3D video. To toggle through the 3D settings, press Menu on the remote (in the center of the row above the arrow toggles) and use the down arrow to go to the Picture sub-menu. Press Enter then with the arrows go to 3D and press Enter. Under 3D Mode, you can toggle with the left and right arrows through Off, 3D, 2D upconverted to 3D, side by side images or two images stacked one over the other. Press Enter to save the setting. Press Menu several times to exit the menu system.
If you do have the UN40D5500 and are trying to disable the 3D audio, press Menu and go to the Audio sub-menu. Then look under the digital audio options (SPDIF).
For other manuals for Samsung devices, go to http://www.samsung.com/us/support/downloads .
I hope this helps.
Oct 21, 2013 | Samsung "UN40D5500 40"" LED TV "
SamSung TV Manual
You can check the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dcf7891b289297c49c9a8bca9143d8bd&modelid=23870046&q=Samsung+UN40D5500
Nov 13, 2011 | Samsung 40 UN40D5500 TV
Samsung UN55B6000 54.6 in. LCD  HDTV Logo
562 people viewed this question
Jerry Greenberg
Jerry Greenberg
