Question about Fisher and Paykel (IWL12)
Gw612 The cold water keeps running into the machine even after the machine finished the cycle. I turned he machine off and on and it helped the first time, but problem came back and turning off and on doesn't help. Can't hear that typical click that it used to make when water was turning on or off.
    Problem Solver:
  • 17 Answers
Your cold water valve has failed and needs replacing, quite an easy fix. To get to it first unplug from wall, next remove water hoses from the machine, next lift the lid up and then just pull it off, next remove the two Phillips head screws at the of the rear of display console, lift off then unplug from motor controller, valves are now visible and are the parts which the water hoses where removed from, if they are blue in colour you will need to replace both hot and cold valves as the blue ones are a single unit but if they are white in colour you can replace the one that is not working as they are separate units. When removing the valves it will pay to cover the brown motor controller computer with a towel so as not to accidently get any water in it when removing as they do tend to hold a little abit inside. You can source parts from fisher & paykel you will need to quote the model number which is GW612 and the serial number aswell with that model as there can possibly be two types of valve available for that model, so keep them numbers handy when ringing them. Make sure you have display console fitted first aswell when putting it back together before fitting the water hoses just to make sure you don't accidently get any water on main computer board as this will kill it completely.
Posted on Aug 21, 2013
SOURCE: Washing machine not draining and finishing cycle
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Posted on Nov 01, 2007
vest6
  • 196 Answers
SOURCE: washing machine
Depending on the age of the unit:
Possible minor leak at the pump.
Possible leak at the spin bearing/boot seal.
Posted on Dec 30, 2007
  • 28 Answers
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Posted on Jun 17, 2008
  • 4 Answers
SOURCE: Fisher & Paykel smart drive
The small leak may have been enough to blow the fuse under the control panel.
I had the same trouble with my F&P smartdrive 701.
Take off the control panel by undoing 2 screws and you will see the blue plastic control box in the tray on the machine (not the other blue circuit board box under the push buttons). Open the control box (1 screw and click open) to see an ordinary fuse. Hopefully this is blown and the new fuse, a clean up of leaking water, and some plumber's thread tape on the hose connector to stop future leaks, and you should be up and running.
Good luck.
If it works - give a small donation to your favourite charity!
DIY Eddie.
Posted on Sep 15, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Our washer dryer is leaking water after the drying cycle. Everything seems to be fine just after the cycle has finished but in the morning the floor is covered in water. It seems to be coming from the...
Hi. I take it that the machine is of the condenser - dryer type?
In these machines, during the drying cycle, warm air is circulated inside the drum and a cold plate is either splashed with cold water or has cold water running through it, causing moisture from the clothes to condense on the cold plate - just like moisture in a room condenses on a cold window pane on cold days.
If your machine is continuing to fill up slowly with water after it has been switched off, then I would suspect the cold water inlet valve isn't closing properly. This is likely due to a build up of grit inside the valve.
If you turn off the cold water supply you will be able to remove the cold supply pipe from the machine and - hopefully - see some of the grit on the filter gauze. The grit possibly causing your problem is already inside the elcetically controlled inlet valve, so it may need to be removed and cleaned or replaced.
You should be able to check if this is the problem by just turning off the cold water supply to the machine. No supply means no water can get into the machine, so it shouldn't fill up overnight.
Before removing the filter down at the bottom of the machine you could turn the machine on to a spin or pump out cycle - that way you shouldn't need wellington boots when you removed the filter :-)
Hope this helps a bit. If not, add a comment and I will try to help you further. D.
Jul 09, 2008 | Hoover Washing Machines
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
