Question about Suburban Hot Water Heaters - All
Komfort 2003 travel trailer
Can not find a fuse for the hot water tank which does not have 12volts to the board
  • 499 Answers
There should be an ON /OFF switch inside, do you have power there? if you do you have a bad switch.
Posted on Nov 07, 2013
How do I start a 1973 komfort travel trailer water heater?
See if big red knob has a PILOT or LIGHT setting and put it on that setting. Next look at knob on bottom-- it should have a circle cutout on it that needs to align with the pilot push button. The cutout lets the button be pushed in. While holding button in---light the pilot and keep holding the button in for about 3 minutes. If everything is working right with the water heater, after 3 minutes or so you can let go of the button and the pilot should remain on. If it stays on. turn the smaller button to the run or heat position and the big burner should come on. Then set the big heat control knob for the heat setting you want.
May 20, 2015 | Water Water Heaters
Why hot water heater on my cedar creek travel
You needed to post more info. does it have power to the heater. Is it electric or gas? if electric and it has power to the heater you need to check with an electrical tester if there is power across the element terminals, If not it needs to be replaced
Oct 12, 2014 | Water Heaters
I would like to know how to turn on (run) 110 V for the water heater on a Conquest/Gulf Stream Travel Trailer?
Must be filled with water or elements burn out
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If water heater is plugged in and outlet has power... then water should be hot.
If no water inside tank, and tank is plugged in, and outlet has power, then element is burned out.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 11, 2014 | Water Heaters
Bosch2500LP tank less HW flashing code C7 no hot water. What to do?
C7 is a fan code, either blown fuse on the board, bad board, or bad fan. Fan needs 24VDC, if you get voltage to your fan and still have C7, the fan needs to be replaced. If no voltage to the fan, its either the fuse or the board.
Aug 18, 2013 | Bosch & Tankless LP Hot Water Heater
My suburban dsi rv hot water keeps throwing breakers
Appears to be a short in tank circuit probably cause by a water leak in tank. These usually wear a rusty hole in the tank inside the cover and are not seen unless the thermostat covers are taken off. I would remove them and do a visual thoroughly. Anytime a fuse blows or a breaker trips is always a dead short unless you have a bad breaker. I would check those as well for vibrating, chattering noises, and/or smoking. If any of this persist, replace breaker. A melted heat element could trip them, but not usually for it leaves an open circuit instead of a shorted one.
Feb 19, 2013 | Suburban SW10DEM Gas Electric Water Heater...
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water heater is not working correctly on electric
Check that the by-pass valve(s) on or near back of water heater are in the proper position. If your stumped on how they should be for normal operation, remember this. Cold water has to flow into bottom of tank, so that valve needs to be open straight into that fitting. Then the hot comes out the top, so that valve has to be open as well. Any valves in between those lines need to be closed, otherwise it will mix cold and hot . If still not sure, get back to me, with location of any valves there, and I'll guide you through it.
Apr 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
2007 hot water heater leaking
You will be happier if you replace it
Repairs seldom last very long with this type of problem
Mar 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Suburban Hot Water Heaters - All Logo
60 people viewed this question
Top Suburban Water Heaters Experts
Jay Plesset
Gene Haynes
Are you a Suburban Water Heater Expert? Answer questions, earn points and help others
