Question about Kitchen Ranges
Gas stove Change from gas to propane
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Model number?
Posted on May 03, 2013
MNTECH
  • 1543 Answers
SOURCE: Natural gas to propane
GE is one company which generally includes all necessary parts and instructions for conversion to LP with the range without having to order or purchase anything extra. Check the mini manual in the white envelope pasted to the back of the range for instructions. Generally, the LP orifices are in a metal holder near the gas regulator (right where the gas connects to the range). You will have to flip the plunger in the center of the regulator and turn down the collar (with a 1/2 inch open end wrench) on the oven burner and broil burner about 3 full turns. Air shutters are usually OK without any adjustments.
Posted on Sep 17, 2008
  • 172 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
jyackle5
  • 8197 Answers
SOURCE: Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
How do I switch my electric stove over to propane?
You can change a natural gas stove to propane or go the opposite, but you cannot make an electric stove into a gas stove. You will need to buy a new stove if you want to go that route. Sorry.
Sep 03, 2014 | Kitchen Ranges
Problem with Kenmore 970-334780 Gas Kitchen Range / propane gas /to natural gas
hello Lorraine,
Most gascookers heve the possibility to change from LPG to natural gas.
You need to change the injectors. The holes in the injectors for LPG are smaller that the ones for natural gas.
I send you a link of Ebay where you can see what you need to look for.
Sometimes the oven can give a problem when it is gas too.
Kind regards, Dik
14results for natural gas cooker nozzles
Nov 20, 2017 | Kenmore Kitchen Ranges
I need to change my frigidaire oven orficis from natural gas to propane?
how do i change my frigidair cook stove from nataul gas to propane modle fgfl67dck
Sep 16, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool model SF385PEEQ0 Gas stove was on Natural gas we have propane is there an adj or part needed as burns yellow flame!
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Jun 18, 2010 | Whirlpool SF325 Gas Kitchen Range
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Wanting to change gas stove to propane
yes. the ports are different diameters. try www.partsselect.com
Aug 20, 2009 | Kitchen Ranges
CONVERTING TO PROPANE FROM NATRURAL GAS
just need to change out orifices in gas line natural gas company should have new ones in stock
Aug 23, 2008 | Tappan TGFS_63 Gas Kitchen Range
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
