Question about HEWLETT-PACKARD M1212nf All-In-One Laser Printer
Initializing press machine will not fax and just says initialing
    New Friend:
Reconnect the flatbed if the probleb still then u have to change the fatebed
Posted on May 29, 2014
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Machine error 71
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Nov 15, 2010 | Brother IntelliFAX 4100 Laser Fax
My machine is only a fax receive. I cannot get it
If the machine is set to FAX receive mode, you cannot receive a call.
You can change the receive mode from the Control Panel of the Brother machine by choosing Initial Setup and the Receive Mode menu or pressing the RECEIVE MODE key on the Control Panel.
Jun 20, 2010 | Brother MFC790cw All-In-One InkJet Printer
"Broken Registration"
U need to press "STOP" to return to idle state.
If this Error Message is repeatedly displayed, machine programming
has become corrupted.The machine must be re-initialized.
Pressing *13 and ON the machine, it will re-initialized the fax.
Jan 03, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Panafax DX800
On the fax press function and the number 7.
Then there is a seperate monitor button that needs to be pressed 4 times.
Next press * and you will see in the display that you have entered into service mode.
press the down arrow until you get to #6 ram initialize and press SET.
arrow down until you see ALL JOB CLEAR and press * this will show ram initialize for a few seconds and then go away. Memory has now been cleared.
Aug 07, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panafax UF-585
You can find that option in Service Mode 6 (Ram Initialize).
Hit Function + 7
Hit Monitor 4 times, then " * "(star)
Press 6 for Ram Initialize
Option 14 (All job clear) is the one you are looking for.
Hit enter and it will run for a few seconds and reboot itself.
Jan 14, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Factory reset
  1. "Function" key + "7" +"monitor" key 4 times +"* " to enter service mode by pressing key one by one.
  2. Select "Ram Initialize" by using "up arrow" and "¯ " and "set" key.
  3. Select "Flash memory clear"
by hhammama
Nov 22, 2007 | Panasonic PanaFax UF-8000 Laser Fax
HEWLETT-PACKARD M1212nf All-In-One Laser Printer Logo
32 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
