Question about Garden
What can I substitute for Garden Way 1738157 hydraulic oil?
I have a 1990 Troy Bilt gtx20 tractor (same as Bolens gt2000 duratrac) I need hydraulic fluid for it. Manual specifies "Garden Way 1738157" as the hydro oil for the tractor. It also lists three alternative fluids: Mobil 423, Amoco 1000 and Texaco TDH. I can not find any of these oils and no one I have asked knows either.
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
  • 57 Answers
SOURCE: replace drive belt
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
Posted on May 15, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
Troy bilt troubleshooting
might be low oil sensor trying to shut the engine down, on a hillside the oil would go to one side and the sensor is thing the unit is low on oil.
Jul 28, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
May 23, 2012 | Garden
I need to replace the blades on my Troy Bilt 46"
If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
Aug 18, 2011 | Troy Garden
How to change the oil in the 7.75 self-propelled troy-bilt lawn mower.
I believe on that model it has to be pumped out. From the Fill hole.
Aug 20, 2010 | Troy-Bilt Garden
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
REAR WHEEL REMOVEAL
it depends on which style mower most ayp (poulan craftsman husquvarna....) are put on with a e clip they may become froze to it but can be removed. now most mtd (yard man yard machines bolens troy bilt...) have a revers thread bolt with a tapered shaft trust me i worked on theses for 10 years. why would you want to take it off anyway? everything can be done with it still on
Dec 08, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
351 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
