Question about Planet Audio P9725B / P9720 Car Video Player
Cd/dvd will not read.
I place a dvd/cd into my player and it say load then go back to the radio.
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Just bought a 2002 exlorer. can't load cd's into cd player. reads cd error
I have found that any "burned" discs will not be read on older cd/radio combinations. The newer sets will tell you on the box what formats can be read...I also found this to be true on dvd players
Jul 29, 2012 | 2002 Ford Explorer
Rotel dvd player not reading dvd but will read cd
if it doesnt read any kind of dvd discs at all it only means you have been rip off. It happened to my sony dvd player that I bought from this website. I tested it and it only reads cd or audio cd. Good thing my couzin fixes electronics, He checked on the lens and it turned out that the lens has been replaced with an audio/cd lens like the one we use for our car stereo. Too bad!!!
Jan 05, 2010 | Rotel RDV-1040 DVD Player
I have trouble loading CDs. There is a place to
Make sure you are placing the CDs in the drive with the label side up. If the computer can read DVDs, it can certainly read CDs as well. Once the cd is inserted, wait and the autoplay should start the installation program for the software.
Dec 01, 2009 | E-Machines eMachines T3830 PC Desktop
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Planet Audio P9725B / P9720 Car Video Player Logo
46 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
