Question about Mtd Garden
Hydro drive issues
No power or speed while driving and cannot make it up even the smallest incline. The drive belt looks brand new (although some slack, but not falling off). The oil level looks good and clean. Ant help would be greatly appreciated. Mower is a mtd z16 zero turn. Model 53ba1a3g190
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mtd Master
  • 1,917 Answers
Carb out of adjustmemt
Posted on Jun 07, 2014
steveym
  • 11 Answers
SOURCE: i have a mtd 13.5 horse 38 inch cut 6 speed its
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
Posted on May 03, 2009
  • 246 Answers
SOURCE: MTD 50" belt problem
Hello:
There May be a Pulley that the Belt is Not Routed onto.
Use the Breakdown at the Following Site Addy to Locate the Deck and Belt Routing Breakdown.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 246 Answers
SOURCE: Manual or parts list for Moto-Mower Front Tine Tiller Model 500
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
  • 376 Answers
SOURCE: z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
Posted on May 16, 2009
rburroak
  • 14 Answers
SOURCE: MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Posted on Jun 19, 2009
Hydro gear problems
well this could be for several reasons, the least of which you wanna hear... its bad... but depending on the style of drive, I would look at the belt tensioner and belt first. some of these are greaseable and people forget and they become locked up. further answers will require you telling us the style of system, or the brand/style of mower...
Sep 01, 2014 | Garden
Lack of power
I had the same problem with my 2011 i1042. Turned out to be drive belt not snug enough. Installed new drive belt all OK now - plenty of power & speed, no slipping. good luck. (BTW: it was a REAL PAIN to remove and replace the belt!)
Apr 26, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
Nov 01, 2009 | Garden
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Mar 23, 2009 | Nordic Track NordicTrack A2350 Pro...
Hydro.tran.
have you changed the drive belt since new? also check tension pulley for drive belt, if ok and belt is in good condition, you have a bad drive.
Sep 24, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
57 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
