Question about Husqvarna Garden
Husqvarna 240e I have a Husqvarna 240e and can't get the cover off to replace the chain. Got it loose but there appears to be a something holding it on.
  • Husqvarna Master
  • 1,807 Answers
Pull the chain brake handle back to release the tension off the brake band and it will come right off..
Posted on Apr 30, 2013
SOURCE: husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Posted on Nov 11, 2008
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: how do i release the brake spring on a husqvarna
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or to a work surface,
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 01, 2010
SOURCE: I have a Husqvarna 345e chainsaw. Can't get the cover back on.
That metal band you see which is preventing you from putting on the cover is part of the chain break mechanism. You were suppose to disengage the break before taking off the cover (I did the same thing). To get it back together you need to disengage the break by a tricky procedure and that will make the band diameter larger so it fits over the clutch. To force the band open, you need to first place the cover over the two bolts that hold the bar. As you already know, the back of the cover will not be able to fit over the clutch. Now in this angled position, bend (force) the break lever down (gray thing on top) until you can force together the sproket in the cover onto the mating pastic fitting built into the break lever. Now you can use the break lever to force down the internal spring and open the metal band. That will expand the stainless steel band and it will fit around the clutch. If you now push down on the back of the cover it will snap in over the clutch. Once you see how it is done, it is not so hard, but it is tricky because you are forcing some of the parts slightly out of position to get it back together. .
Posted on Sep 19, 2010
I need to know the correct fuel ratio for a Huska Vona 235 chainsaw
50:1. Your manual is here.
[PDF]OM, 235 e/ 240 e, 2008-02, Chain Saw - Husqvarna www.husqvarna.com/.../HUSO%2FHUSO2008_USen%2FHUSO2008_USen_O08020...
  1. Cached
235e 240e. Operator's manual .... You will find the following labels on your chain saw: ..... recommended (a lean mixture may mean that the fuel lasts longer than ...
http://www.husqvarna.com%2Fddocdownload%2FHUSO%252FHUSO2008_USen%252FHUSO2008_USen_O0802031_.pdf&usg=AFQjCNHmUdP3dUYTbfqmTs7Z7SATwGd1Nw
Jan 23, 2017 | Garden
Husqvarna Chain Saw 240
Yes that saw does exist..! What is your question regarding it.?
Mar 16, 2014 | Husky Husqvarna Chain Saw 240E w 16in bar
Idle screw husqvarna
Can be located on the carb.! it is on the left hand side of the saw below the primer bulb but above the L/H screws
Mar 08, 2014 | Husky Husqvarna Chain Saw 240E w 16in bar
How do you remove the carburetor on a Husqvarna 240e chainsaw?
Remove the handles, then remove four 8MM bolts from the bottom securing the engine case. The entire assembly will then rotate upward,
allowing you to remove the two 8MM nuts and carburetor.
Oct 02, 2012 | Husqvarna Garden
I can't move chain tensioner on 240e.
The adjuster is a tooless system on this machine housed in the chainbrake cover, it may be the gear mechanism has jammed or stripped one of the gears, remove the brake fom the saw, remove the cross head screws covering the adjuster mechanism, clean, or replace damaged components.adw1_3.jpg
Sep 03, 2011 | Husqvarna Garden
I have a husqvarna 240 chainsaw and I can not get the cover back on over the blade.
I sounds like the chain brake is released.
Husqvarna - IPL, 235, 235e 240, 240e, 2008-01, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2008/HIUS2008_506955901.pdf
See Detail A or B (same pn), pn 503 057940. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 057940 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Husqvarna Garden
How do i release the clutch band to replace chain cover on a 235 e-series
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
HusqvarnaUSA.com
06 1500198
Lou
Mar 17, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 240e muffler comes loose even with locktite and rebored holes. what can I do?
hi you can try using anti vibration washers, these are the type that have allot of little cutouts in them they work very well...hope this helps
Feb 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you adjust the chain tension on a husqvarna 350 chainsaw ?
I don't own a 360, but most saws you have to loosen the two nuts that hold the bar on, and adjust the adjusting screw that points toward the front of the saw while holding up on the tip of the bar. Tighten until the chain is snug, but still loose enough to be able to spin the chain on the bar.
Dec 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350, the chain continues to free spin after trigger is released.
Is the chain loose?
ee42fee.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 29, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
100 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
