Question about Garden
I have a 1990 Troy Bilt gtx20 tractor (same as Bolens gt2000 duratrac) I need hydraulic fluid for it. Manual specifies "Garden Way 1738157" as the hydro oil for the tractor. It also lists three alternative fluids: Mobil 423, Amoco 1000 and Texaco TDH. I can not find any of these oils and no one I have asked knows either. Please advise. Thanks, Tim
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
  • 57 Answers
SOURCE: replace drive belt
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
Posted on May 15, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
I need a Troy-bilt service agent in the Geelon, Victoria area.
Hello, Ross -
Apparently, in Australia, Troy-Bilt products are sold through MTD.
I found the following information on the MTD Owner's Centre FAQs web page:
http://www.mtd.com.au/Page/Owners-Centre/FAQs/General/How-do-I-locate-my-nearest-servicing-dealer-for-MTD-Bolens-Troy-Bilt-Yard-Machines-or-Yard-Man-products
Servicing or locating parts for your MTD, Bolens, Troy-Bilt, Yard Machines and Yard-Man products can be done by contacting one of our Rover servicing dealers. To locate your nearest servicing dealer for any of these brands, please click here.
This is the link to the page to find the repair centre nearest Geelong:
https://www.rover.com.au/locator/
Don't be confused with the Rover logo.
Best wishes.
Jan 21, 2018 | Troy-Bilt Garden
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
Need manual for troy bilt 47035 chipper
About 19,400 results (0.36 seconds) google search hits for "manual for troy bilt 47035 chipper"
pretty difficult to do.
Mar 29, 2011 | Garden
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Will you download parts manual?
    If you are looking for a Bolens parts breakdown, go to ... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=Troy-Bilt&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 select brand (Bolens), enter your model # (not the one you posted, but the full model # located under the seat), click on search and there you have the mower parts breakdown. Dwain
    May 29, 2009 | Garden
    Garden Logo
    407 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
