Question about Canon imageRUNNER ADVANCE C5035
Service mode switch for importing custom wallpaper
I need instructions on what switch needs activated within the service mode to allow me to change the wallpaper on this device
Haw to remowe icon like an circle -sihronizacia
Samsung GT I9000 User Manual Switch To The Silent Mode Change Your Ringtone
The link above is the manual on the Samsung and the page that you need to read and follow.
Select a wallpaper for the idle screen
1 In Idle mode, press [
2 Select an image.
3 Save or Set wallpaper.
Select
Samsung is not responsible for any use of default
images or wallpapers provided on your device.
Mar 10, 2015 | Samsung Galaxy S GTI9000 Smartphone
Why do lights flash while on trailer on 2014 street glide
The bike senses movement (like someone is stealing it) and activates the "Smart Security System".
You won't have an actual alarm unless you have the optional alarm installed.
You need to put it in "Transport Mode"
In the transport mode, the Harley-Davidson Smart Security System is armed but the motion detectors are inactive.
The motorcycle can be transported on a trailer without activating the alarm while the starter and ignition remain disabled.
Here's a video how:
http://www.youtube.com/watch?v=tA35I8RWI_s
And written instructions:
With an assigned fob within range, turn the ignition switch to IGNITION.
Before the security system lamp goes out, turn the ignition switch to OFF.
Within three seconds, simultaneously press both the left and the right turn signal switches.
After the turn signals flash once, the system enters the transport mode.
With the fob removed, the motorcycle can be moved without setting off the alarm.
May 18, 2014 | Harley Davidson FLHX Street Glide...
MY LAPTOP DOES NOT ALLOW ME TO CHANGE MY WALLPAPER
right click the desktop and go to properties. click change background. If your background is custom made i think you need a jpg or gif picture. once chosen hit apply thehn ok
Sep 07, 2013 | Computers & Internet
Which type of stator do i order for my 2003 fxdx
when it comes to electrics and harleys always buy the harley davidson oem stator right from your local dealership.
Feb 26, 2013 | 2003 Harley Davidson FXDX Dyna Super Glide...
Hi, I am getting a problem regarding changing the wallpaper on my desktop. Please Advice on this.
Windows 7 Starter does not allow you to change the wallpaper. You will need a third party solution such as  Stardock My Colors. This website gives you quite a few options: http://www.instructables.com/id/Windows-7-Starter-Easy-way-to-change-wallpaper/
Mar 29, 2011 | Dell Inspiron Mini 10 Notebook
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
How to turn off wallpaper on my sgh i450
Simply turn on The Active Standby Mode......
Menu->Settings->General->Personalisation->Stanby Mode->Avtive Stanby Mode [ON]
Thats The only Solution...
Bye Take Care
Jun 07, 2009 | Samsung SGH-i450 Cellular Phone
Dear Sir How Can i USE One-Wallpaper For All User In Active Driectory Thank You Md shiful Isalm 01713489184 shifucv@yahoo.com
Hello, you would need to create a GPO that gets applied to all computers in your AD domain. Within the GPO you can specify the file name of the background image you plan to use. Be careful of different screen resolutions as the image may be distorted from machine to machine especially if you have Desktops & Laptops. In that case you'll need 2 different GPOs pointing to different image files or you can do some more intelligent scripting to determine screen res.
Should be set here:
\User Configiguration\Administrative Templates\Desktop\Active Desktop\
  • Enable Active Desktop; and
  • Active Desktop Wallpaper
Nov 13, 2008 | Mercury P4VM800M7 Motherboard
Setting our nigh-time message
Where is this message "set?" It should be in a custom service in your automated attendant. Which Custom Service is set up by your installer under Time Service for Night Mode. In addition, your Automated Attendant has to have a correct schedule to designate when Night Mode is in effect or be set to be under PBX Control. If the latter is true, your greeting will automatically play when you put the system in Night Mode.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jun 20, 2008 | Panasonic KX-T7633 Corded Phone
Canon imageRUNNER ADVANCE C5035 Logo
103 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
