Question about Panasonic PT-43LC14 Television
TV will not power on
All of sudden my TV will not power on. I've owned it for several years and it has never given me a problem. I did recently replace the lamp but considering the age of the set, it was justified. Even so, it has been weeks since the change out and it has worked well. This morning I went to turn it on, the indicator light flashed green for a few second, then red, and the TV completely shut down. Not once did the screen light up. I inspected the lamp but it is not burned out. Should I have replaced something else? What else can I do to resolve this?
    Habit-Forming:
  • 187 Answers
Inspect the lamp again. When you replace it, make sure you DO NOT TOUCH the glass. Make sure all doors and covers are securely in place before you turn it on.
As a rule, expensive lamps have a very short life.
Posted on May 03, 2017
2 Suggested Answers
  • 87 Answers
SOURCE: How do i know if the ballast needs to be replaced?
Did you buy and OEM Panasonic lamp in a Panasonic box?
Posted on May 12, 2010
I've got a Sony Wega KDF-55E2000 there was an
replace teh lamp its might have exploded if its okey check the power supply board but most likely the lamp needs replacement
Jul 16, 2013 | Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
Feb 03, 2013 | Samsung HLN467W 46" Rear Projection HDTV
My 61 inch sony DLP ,i think a '07 just black out
You check the power supply section and the horizontal section
May 04, 2012 | Sony Televison & Video
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Toshiba 62HM196 "flickers"
You may have to wait for the problem to become more frequent to see what is wrong.
Mar 12, 2012 | Toshiba 62HM196 62 in SDTV DLP TV
Playstation 3 does not output to my Mitsubishi 62825. It has in the past. I've tried RGB and component. Neither work. Using the same cables it works fine with my girlfriends Sony Bravia. The tv has...
Is your girlfriend's television higher resolution? If so, the ps3 may be configured to output a signal that is too high for your mitsubishi. With the ps3 off, insert either the component or the rgb to the back. The turn on the main ps3 power switch so that the red led turns on. then hold down the 'power on' button. it will beep initially, then beep after about 3 seconds. This simply resets the output to the connected cable in a normal resolution.
If this fails go to settings>video output> and play around with the settings there. note you may have to do this on ur girlfriends tv to be able to see what you're doing...
Aug 26, 2011 | Mitsubishi WD-62825 62" Rear Projection...
I've owned an OKI LCD TV (TVV32TD) for more than three years and recently it started to turn off by itself. At the beginning it happened a couple of hours after turning it on. It seemed like it came to...
Maybe the problem is in the power supply board.Ethier the capacitor or the regulator transistor.The trnsistor can know that is deffective by using digital tester not for looking the apperance and also the capacitor.So its better to check by the authorized technician.
Jul 04, 2011 | Televison & Video
My Sony Trinatron has suddenly displayed a dark screen on all channels. You can see the picture but looks like it's nightime. I've tried ajusting the brightness but no result.
does the TV bring out sound even as the screen display is dark?
Problem should be from the TV lamp/bulb. When a TV bulb/lamp is dying, it makes the pictire on the screen become dark and very hard to see.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Panasonic PT-43LC14 Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
