Question about Dynex DX-LDVD19-10A LCD TV
Cable card Is my TV cable card compatible?
    Top Expert:
  • Dynex Master
  • 74,198 Answers
Yes. It is compactable. Refer its user manual for details.
Posted on Apr 30, 2013
Can i connect my archos 97 cobalt to tv
• Micro USB 2.0: Mobile Transfer Protocol (MTP)
• USB host via OTG
• microSD (compatible with 64 GB cards)
• HDMI output (Mini HDMI / HDMI cable sold separately) If you have the Mini HDMI to HDMI cable you may be able to connect to HDMI input of TV, or try USB out of the device to Computer input on the TV....
Apr 30, 2014 | Audio Players & Recorders
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Is the steelseries 7h usb headset compatable with the ps3
Hello Sixlittledev,
Although the 7H USB headset is not natively supported by PS3, you may be able to get it to work if you have a headphone jack in your TV.
You will need to connect the headset in the following manner:
Headset microphone cable -> USB card -> PS3
Headset audio cable -> 3.5mm extension cable -> TV headphone jack
Although we do not guarantee compatibility and this method is a bit cumbersome, you can get it to work this way.
Mike S
SteelSeries Support
Http://www.steelseries.com/support
Dec 03, 2010 | Steel Series Steelseries 7H USB Headset...
I connected my computer to my TV via a VGA to RCA component cable and no image is showing up on the television.
I have two suggestions. First, make sure your TV is set up to receive inputs from the RCA jacks you're plugging the cable into. Second, you may have to change the screen resolution on the computer to something the TV can handle. To do this plug the VGA cable back into your normal monitor. Right click in the field. Left click on properties or personalize, depending on your operating system. Then left click on setting or display settings. There should be a slider bar where you can change the screen resolution. I'm guessing it's probably set too high for your TV. Try reducing it and then plug the VGA cable back into the RCA jack converter. I hope this helps you out.
Sep 29, 2010 | Panasonic TH-37PX60U 37 in. Plasma HDTV
I have saa7130 tv tunner card and i also install successfully above card but i have not a programme to run tv progarrme through cable but programme compatible to run the tv programme
please check back drivers tv tuner which has been fixed, if it was running perfectly or there is a miss, usually if the driver installed again the tv tuner can be used again. or for more open jelasanya tv tuner application and click on help, there you are given instructions in its use ordinances. thanks.
Feb 27, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Can i hook a tv up to my E627 laptop?
yes you can... must buy a captured card with tv tuner compatibility. plug in the cable then choose your best tv movies.
Jan 20, 2010 | E-Machines M2350 Notebook
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
How do i connect my dell d620 laptop to my lcd tv i plugged the cable in and my tv doesnt pick it up , but it picks up my dads nec laptop????
Does your dell d620 has a tv tuner video card, you also need to double check if its compatible or not.
Nov 04, 2008 | Computers & Internet
S-Video Output and SD Memory
S-Video would allow you to run your laptop onto a TV, you would have to buy an S-video cable and have a tv or box that is s-video compatible or buy a converter. You would connect the cables to the tv from laptop and Using th <FN> and <F5> toggle between lcd/external/both
SD media card reader just reads SD card you have e.g. camera memory cards, data transfer etc.
sd card is inserted pin side down and pushed in till it clicks in place
Apr 21, 2008 | Computers & Internet
Blurry and shaking pictures on LCD
refresh rate, likely
try to adjust to a compatible rate. the monitor manual will give you its compatible rates. the video card should have that rate available. if not, you may damage the monitor with the wrong rate.
stop and try another monitor that has a refresh rate available on your video card.
good luck
mark
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Dynex DX-LDVD19-10A LCD TV Logo
19 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
