Question about 5901 Security Remote Start System
Reprogram viper remote - 5901 Security Remote Start System
Viper 7153v remote start. I had some work done to my 2005 Ford F250 and not when I use the remote start, the truck will start,shut off in about 15-20 seconds, then restart and continue the cycle.
Just had the same issue with my remote start. 2006 f-350 with a 6.0 powerstroke. Remote start module was in virtual tach mode and that does not work with diesel engines. Just had to have the remote start reprogrammed and put back into tach sense mode. Hope this helps.
Oct 07, 2016 | Remote Start System
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
Why doesn't remote start work?
It says its a Viper alarm system. . If the alarm system is active, reprogramming the ignition keys was a waste of money. The problem is in the control box for the viper alarm system. It has disabled the ignition because it thinks that is being broken into. there are sensors that monitor the the vehicles vibration and is probably a problem with one of the sensors or maybe even the control box itself.
Dec 24, 2015 | Remote Start System
How do I reprogram a viper 5101 remote starer
on remote press the middle button for 15 sec. after three flashes on remote, put key in ignition and turn ignition on but dont start it. press button on antenna, release and then hold until horn honks or led flashes on antenna. lastly press lock within 5 sec
Jul 30, 2014 | 5101 LE 1 Way Car Remote Starter System
Viper 487v remote wont work
reprogram the remote start
Dec 06, 2012 | Remote Start System
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
My viper alarm remote just beeps flashes TX and will not unlock doors or disarm my system. It has a new battery.
Try to reprogram this. If this routine does not work please let me know and we will try something else
May 06, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The battery was taken out of the viper remote, now I can't get it to communicate with the car to lock,unlock start.
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Nov 30, 2008 | 5900 SST 2-Way Security System / Remote...
5901 Security Remote Start System Logo
20 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
