Question about Roofing
Water drainage runoff - Roofing
Water drainage runoff from driveway
  • 4 Answers
Cement would work fine just make sure it's level and wAter can drain into it
Posted on May 16, 2013
How deep to dig a french drain side of a driveway
It all depends on the soil conditions, you want to consider the size of your gravel that you use for your french drain and next thing is,
few days before you start to dig your drainage make sure you should contact your local utility company and driveway contractors. Recently, my husband and I just moved into a new house in Long Island area, and I wanted to install a French drain which would help me to hold water. So I got in contact with the local utility company and driveway Long Island contractors to have all the underground utility lines of our property which are located and marked.
Apr 11, 2015 | Plumbing
I need to know an example of each part of the water cycle listed below: a. Evaporation b. Precipitation c. Runoff d. Condensation e. Transpiration
Hi Stan:
Evaporation - Hot sun shining on damp ground in morning. The moisture on the ground EVAPORATES as the ground dries.
Precipitation - Rain falling onto the ground is PRECIPITATION
RUNOFF - When rain falls onto the ground, some of it is absorbed into the ground. The portion that is NOT absorbed becomes RUNOFF in that it runs off the surface that it fell on.
CONDENSATION - Air contains water vapour, and the higher the temperature, the more water vapour it is capable of containing. This is expressed as relative humidity. When warm air that contains lots of water vapour is cooled, there will be a temperature reached where it cannot contain all of the water vapour that is present, so the excess water vapour CONDENSES on cooler surfaces. This process is called condensation.
If you Google TRANSPIRATION you will get a link to Wikipedia where you can read the definition. If you have problems with my explanations, you can also use Wikipedia to get the formal definitions.
Mar 13, 2015 | Washing Machines
The water is dripping from the runoff, what is the problem?
runoff ??? do you mean safety vent.they are replaceable and very necessary do not plug off .if you have ever seem one explode you would know why not .
Feb 16, 2015 | Water Water Heaters
2005 kia /excess condensation in trunk
might check for plugged up drains in corners below the spare tire area and see if weatherstripping is in good shape around trunk.. also check for runoff of water with the trunk openned by slowly pouring water over base of back window..check for leakage..ansd plug leaking aereas
Jan 22, 2013 | 2005 Kia Amanti
The little vent above the words turbothermic plus is spitting out water during the cycle.
The fan assembly's drainage path is clogged. With time, food residue cloggs up the drainage path, inside the "Turbothermic" fan, and water accumulates during the drying cycle. The control panel, that houses the fan assembly, will need to be removed. Door panels will also need to come off. Unplug wires and drain hose to the fan, and loosen the round fan grill that secures the fan assembly (located inside the door). Take apart the fan assembly; unclogg drainage path and hose; and wash all parts. Re-assemble, install, and plug, the fan assembly, drain hose and door panels. Good Luck.
Oct 27, 2010 | Miele Premier-Plus Built-in Dishwasher
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Water leaks from bottom of refridgerator
Automatic defrost units have a drain for the melt water to leave the cabinet and travel to a pan under it. That drain is sometimes not easy to find and it may be clogged with debris or mold so the runoff can't leave as it should.
Oct 24, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Runoff water not draining
The drainage holes are located just in front of the rear wheels under the car.
(near the support for hoisting the car)
The holes are covered by small rubber flaps.
These holes tend to clog so the water can no drain.
You can easily clean those with the car parked somewhere.
Cheers,
Andrew
Apr 10, 2009 | 1995 Chrysler LeBaron
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
Roofing Logo
1,020 people viewed this question
Top Roofing Experts
bobfiala
bobfiala
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Roofing Expert? Answer questions, earn points and help others
