Question about Garmin nuvi 1450 GPS Receiver
How to erase the favourite addreesses - Garmin nuvi 1450 GPS Receiver
  • Garmin Master
  • 2,130 Answers
1. Turn on the unit with the power button.
2. Enter PIN if required.
3. Allow unit to boot to the main menu.
4. Press the Tools (toolbox) icon.
5. Press the white down arrow in the lower-right corner of the screen.
6. Press the folder icon labeled "My Data".
7. Select the taskbar labeled "Delete Favorites".
8. Select which favorites you want to delete by setting a checkmark next to the name. Press the white down arrow in the lower-right corner to scroll through the favorites list. You can delete the entire list by choosing "Select All".
Posted on May 01, 2013
How do I delete all the favourite addresses on my Garmin nuvi 50 serial number 2AT174175 as none relate to me and then insert a new home address. No Edit button appears on screen.
Do a hard reset.
To hard reset your Garmin nuvi 50LM, do the following instructions
  1. Start with the device OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the device ON.
  4. Release the power button when the device powers ON. You will see a new message: "Erase all user data?"
  5. Remove your finger from the touch screen when this message displays.
  6. Touch Yes.
The device will now reset. Follow the on-screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
Feb 28, 2017 | Garmin GPS
Drivers side window
i HAVE ADDREESSED THIS ALREADY
Jun 19, 2012 | Cars & Trucks
My Garmin nuvi 255w thinks we are in Belgium instead of in UK, so can't recognize British cities, and gives Belgian addresses for fuel, accommodation, etc. 'View map' shows the approximate...
You can try two things to try and get the Nuvi to act normally:
1) soft reset: Press the power-on button for at least 20 seconds - starting from power off. It should restart.
2) master reset: This will revert to factory defaults erasing all POI's, Favourites, Tracks, Routes etc. From power-off hold the lower right corner for at least 20 seconds while pressing the power-on button once. A question should appear to erase all user data. Press yes and it will revert to factory defaults.
Jul 10, 2011 | GPS
Dear Sir.. I forget my alvarion bmax ip addreess. How to reset it? It's my first time to ask here. So I hope that I can get the solution here. Thank You
Alvarion have no IP, u must give a IP-Adress with <SET IP>
u will have to contact alvarion customer support center for more help on this.
Post back for more solutions.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Computers & Internet
How do I delete my favorites?
To delete all favourites:
With the satnav turned off press the bottom right corner of the screen with your finger and while pressing it turn it on.
Keep your finger pressing until a pop up message appears
Press yes and all user data will be erased. This will reset all original settings.
If you only want to delete some favourites:
Press Where to, press Favourites, select one to delete, press Edit, and press Delete.
This way you can delete them one at a time.
Aug 12, 2010 | Garmin nuvi 250W GPS Receiver
Nuvi 255w is stuck on the loading maps screen. Computer is not detecting the device when I plug it in with the USB. Its not older then 3 years old andalready having issues.
A system reset might be the best solution but it will erase all your favourites. To reset With the power off press on the bottom right corner of the screen with your finger and while pressing, power on the unit.
Jul 17, 2010 | Garmin nuvi 255W GPS Receiver
I am on wireless network cannot hook up printer according to network magic it sees printer but does not print I have updated the driver
pls check the ip addreess of the print server
ping the ip address from your computer
by>start>run typr "cmd"
ping <ip address>
if you get reply.that means no problem in the connectivity
if it requset time out
check the cable of the print server
Nov 02, 2009 | Computers & Internet
Using favourite-tabs will close IE8b
check if you got IE8 Beta latest version.(I'm using Beta 2)
download and install latest version
Export your favourites
Delete all your favourites
Check if issue replicate with empty folder.
Restore your favourites by small batch.
Check if any set of links triggers the problem.
Jan 09, 2009 | Microsoft Internet Explorer 8
I have just bought a garmin streetpilot i2 second hand and need to know how to reset it so i can delete all the previous favourites and change the "home" address
This will clear ALL user data.
Hold down all buttons in the following order. [Left arrow] <==, WHEEL, POWER. Continue holding down all buttons untill you see a prompt, "Do you really want to erase all user data?" Select "Yes"
Jul 11, 2008 | Garmin GPS
Garmin nuvi 1450 GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
