Hp w1907 i disabled my sound how do i fix it? plz help asap!!
  • Computers & ... Master
  • 5,127 Answers
The HP W1907 doesn't have speakers. Thus, what type of speakers did you previously have? If a previous monitor had speakers, you will need external speakers for your audio output for a desktop computer.
If you have a desktop:
If you have had external speakers connected, first make sure that the audio cable is firmly connected to both the computer Audio output jack (Speaker (lime green) or headphone) and the speakers (if not permanently wired to the speakers). Next check if the cable was damaged by swapping cables or speakers. The next item to check is the volume output (make sure that the audio is not muted). The next item to check is the default audio devices. For a Windows 7 or 8 system, go to the Hardware and Sound control panel. (Under Windows 7, click Start > Control Panel > Hardware and Sound. For Win8, in the Desktop mode, click the Windows key and C together. Go to Settings (in the Charms menu), then select Control Panel. Then follow the Window 7 directions.) Under Sound, select Manage Audio Devices. Under the Playback tab, check that the correct audio device is your default device. (If you recently added a video card with HDMI, the HDMI port may have become your default audio device.)
The last thing to check is the audio driver. Check with your PC/motherboard manufacturer or the site for the audio hardware (often Realtek audio) and check for driver updates. (If you recently updated your audio driver, try rolling back the driver.) You can check the audio device status in the Device Manager. (From the same Hardware and Sound control Panel under Hardware and Printers, select Device Manager.) Scroll down to the audio device and look for a triangle with a red X or yellow exclamation point. Here you can check for updates to the driver or roll back to a previous driver. The names of the Control Panels are slightly different for older versions of Windows but the basic steps are the same.
If you have a Macintosh or Unix system, please add a comment with the OS.
For a laptop, if you use the on-board speakers, check the device drivers, audio output volume and if the service is running. For Windows 7/8, the component services menu can be run by searching for compmgmt.msc . Go to the Services section and expand sections to see if the Audio Service is Stopped. Restart it. (Please add a comment if you need assistance.)
I hope this helps.
Posted on Apr 29, 2013
    Brigadier General:
  • 3,400 Answers
Upper section of my HP w1907 LCD computer monitor is faint. How to fix it?
From the sound of it, you most likely have a blown CCFL bulb in your monitor (there is one on the top and one at the bottom).
You can either buy new bulbs for it and try to replace them (risky and difficult without experience as I had found) or you will need to buy a new monitor.
It is a common problem with them unfortunately.
May 11, 2011 | HP w1907 LCD Monitor
I need fix this problem about '' monitor going to sleep''
To resolve the issue, please follow the steps mentioned below:
1) Go to Control Panel, click on "System".
2) Then, click on "System Protection".
3) Then, click on the "Advanced" tab.
4) Then, click on the "settings" under Performance.
5) Then, select the "Data Execution Prevention" tab.
6) This is where you can disable the "explorer.exe has stopped working".
7) In the Data Execution Prevention tab, select "Turn ON DEP for all programs and services except those I select" option.
8) Then, click on the "Add" option.
9) Then, you have to select the explorer.exe file manually.
10) the "explorer.exe" file will be located in the C:\Windows folder.
This might be a lengthy process, but this will resolve the issue.
If you have any difficulties, you may contact me through my Email address.
suresh0954@gmail.com
Jul 06, 2010 | HP w1907 LCD Monitor
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
No sound when playing video
hi bearly,
this may be due to codec issues, there are special video and audio codecs needed to give sound to webbased films and videos.
try downloding k-lite codec pack or xp-codec install, reboot and try to access youtube again!
good luck
Sep 07, 2009 | HP w1907 LCD Monitor
Red lines on hp w1907 monitor
this sounds like pixels have died on the screen there is no cheap fix for this, its cheaper to buy a new one. if it is still under warranty bring it back as the manufacturer should cover this
Aug 07, 2009 | HP w1907 LCD Monitor
No sound from my HP w1907 monitor
This is a failure in the audio section of the control circuit. Your cable could be at fault or the circuit itself. Try switching cables or try you monitor on a different sound source. if this does not work then it is the monitors sound circuits. This requires a trip to a service center for servicing. Hope this helps.
Apr 07, 2009 | HP w1907 LCD Monitor
Disable sleep mode
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Feb 22, 2009 | HP w1907 LCD Monitor
Solve prob PLZ
go into start, control panel, system management, services. There locate "Windows Audio" and select start on the left side
Sep 22, 2007 | HP Pavilion dv2000t Notebook
No sound
You can try bringing the computer to an earlier point by using a restore point. Make sure that you dont have your audio muted. Go into your device manager and go to sounds and audio devices (xp; its different for vista). If everything is 'drayed out'... go into start/run/ [then type] msconfig Under the tab 'services' look for something that says sound or audio on the far left column. On the far right column make sure it says 'running' if it says 'stoped' thats your problem. If you cant find anything, go to hp.com and download updated drivers.
Sep 20, 2007 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
